Refrig too cold on electric - Fiberglass RV
Old 09-11-2022, 05:47 PM   #1
Trailer: 2013 Scamp 13'
I have a 13 ft Scamp and thus the smallest refrig. It has no controls inside it or around the frame. It’s fine if I use propane bc I can set it at medium. But I can’t adjust it when I’m plugged in. My fruits and veggies freeze.
Suggestions?
Cori A. is offline   Reply With Quote
Old 09-11-2022, 06:54 PM   #2
Trailer: 2006 Scamp 19 Deluxe
Enchanted Mountains of Western New York State on the Amish Trail in Cattaraugus County!
Suggestions?
It should have a model number on the door or door frame. Can you tell us what brand and model # it is?
parmm is offline   Reply With Quote
Old 09-11-2022, 07:15 PM   #3
The controls are on the outside of the trailer there is a vented door , open it and find three controls... 12V/120V/ propane.
The large green one is the 120V switch, behind it is a control knob with the numbers 1 thru 7. That controls the temperature when on 120V.
Be sure that two of the controls are always in the off position whenever one of them is ON.
Also be aware that only the back wall of the fridge gets cold... so if you pack it too tight it will impede air circulation and the stuff toward the back of the fridge will freeze
Old 09-11-2022, 11:04 PM   #4
Thanks! I found it and turned it down. Fingers crossed. Your point about overcrowding is a good one.
Old 09-12-2022, 11:57 AM   #5
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
Cori You can also buy a small battery operated fan to put on a shelf in the fridge to move the colder air around.
Kenny Strong is offline   Reply With Quote
When the cold water is just too cold... TomandCallie Electrical | Charging, Systems, Solar and Generators 14 01-08-2017 10:02 PM
Too cold to glue Reflectix? Ngrimm Problem Solving | Owners Helping Owners 5 05-26-2013 03:24 PM
How COLD is too COLD Gerry General Chat 11 02-05-2011 12:06 AM
MOVING a TOO-TALL cramper into the TOO-SHORT garage! HeathGal Problem Solving | Owners Helping Owners 5 10-19-2010 02:36 PM
Too darn cold! Lainey General Chat 52 12-21-2008 11:00 PM
