Refrigerator issues - Fiberglass RV
Old 09-12-2022, 09:54 AM   #1
Trailer: Bigfoot 25RQ
Mississippi
Refrigerator issues
On the tail end of a trip now and the refridge started acting up. Freezer is 14 degrees but fridge is at 50 degrees.
1. Outside temps are 85 to 96.
2. Camper temp is 70 to 74
Iíve checked the outside venting itís not stopped up. Checked the adjuster in the fridge itís ok and thermistor isnít pulled out.
Have space around everything with a small fan running.
Iím ok with the freezer but the fridge is too warm, any suggestions until I get back home.
Fridge is a dometic 110/propane model 26621BX 2018 Bigfoot 25RQ
snuffy2 is offline   Reply With Quote
Old 09-12-2022, 08:11 PM   #2
Is there frost built up in or around the freezer?
Old 09-12-2022, 10:22 PM   #3
CharlesinGA's Avatar
The X on the end of the model number tells us that the cooling unit was made by a subcontractor for Dometic when their own production got behind. Those cooling units are very poor quality and more prone to failing.
Even the freezer is not cold enough at +14. You can open the cover on the circuit board and find the wire that is coming down from the thermistor and locate where it plugs onto the circuit board, on the upper LH side. If you squeeze the tab and pull the connector off the board, the fridge will go full cold, this will tell you if the cooling unit is working.
Is the fridge not working properly on both LP and electric? or unst not on one or the other?
While they would like to sell you their product, ARP does provide a lot of good troubleshooting information. This web page should help you troubleshoot the issue.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 09-13-2022, 06:19 AM   #4
Mississippi
Itís dead
I was talking to dinosaur electronics, we sent it to full cold like one of you mentioned. Fridge still went up three degrees freezer one degree, this was as the day warmed. We just bought a small 4.3 CF electric from Home Depot to finish the trip.
Thanks for the replies
Old 09-13-2022, 06:20 AM   #5
Mississippi
Charles
What web page?
Old 09-26-2022, 09:21 AM   #6
Mississippi
Just for extra information my paperwork on the 25RQ listed the dm2662lbx as the equipment onboard, it’s actually a DM2852, just saying check the information on the fridge.
Old 10-10-2022, 05:33 AM   #7
Mississippi
New info
Now that Iím home Iíve had more time to check out the refrigerator. Sat morning I turned it on with using propone then disconnected the thermistor, Sunday morning it was 10 degrees. Doesnít this point to the thermistor being bad?
refrigerator
Refrigerator issues - and resolutions - 2005 Casita Joe & Cherie General Chat 3 06-08-2016 04:08 PM
More issues with water in refrigerator service area BatDude Problem Solving | Owners Helping Owners 7 11-30-2015 06:55 PM
Real world weight issues Legacy Posts General Chat 2 05-02-2003 05:52 PM
