Removing Old Flaking Paint - Fiberglass RV
Old 05-08-2020, 02:15 PM   #1
Hello!! I am a new owner of a 1974 Boler and the previous owners painted the interior but maybe used poor quality paint?? Itís flaking off EVERYWHERE 😭 Iíve tried using a bristle brush to get it off but itís really only taking off the spots that were flaking... WWYD? Should I sand/scrub the worst areas and then just paint over everything?
Fabricmama is offline   Reply With Quote
Old 05-09-2020, 07:36 AM   #2
Trailer: 1978 Boler
Almonte, Ontario
My suggestion would be to:
-Continue to bristle brush the remainder of the painted surface,
-Get a good exhaust fan to suck the air out of the trailer and a good face mask
-Use cleaner vinegar to spray the interior in patches, allowing it to sit a few minutes and brush again (This is the best non-corrosive solvent for latex paint which I think is the problem you are dealing with)
Once the whole surface has been cleaned and hopefully stripped of any remaining loose paint, I would check for are any raised edges and lightly sand the edges. But if what is left is fairly flat, the next step is to apply a good all-surface adhesive primer. This will ensure that the primer holds everything left behind together, will bond to the newly cleaned surface and if judicially applied level out the patch edges. After that, choose your new wall colour making sure that it is compatible with the primer.
Nicolas is offline   Reply With Quote
Old 05-09-2020, 08:36 AM   #3
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
If you can't get it off scrubing with a bristle brush it will probably hold new paint.
The POs may have used good paint but just poor prep.
Clean and grease free surface, today's paints will stick to about anything.
Fred
I'd rather do it myself, done right or not. Isn't that what a hobby is all about?
https://www.fiberglassrv.com/forums/...ler-55601.html
FRED SMAILES is offline   Reply With Quote
paint, vin
Inside Cushion Covers Flaking Tricky Mik Problem Solving | Owners Helping Owners 8 09-18-2018 10:14 AM
Removing old "Paint"? ArtandLarry Problem Solving | Owners Helping Owners 14 07-06-2016 06:39 PM
Defective gelcoat? Chipping/flaking. mglyons Problem Solving | Owners Helping Owners 8 04-04-2016 01:15 PM
Zep flaking problem Janb313 Care and Feeding of Molded Fiberglass Trailers 3 05-28-2015 06:53 AM
removing paint from Boler outside Judy Powell Problem Solving | Owners Helping Owners 1 07-10-2007 11:01 AM
