Removing Rat Fur and putting back? - Fiberglass RV
Old 09-21-2018, 12:37 PM   #1
Trailer: In the Market
Iowa
We have a 1991 13í Scamp and yesterday I noticed a musty smell inside, and a couple stains on the rat fur that looks to reveal a couple possible leaks. We are planning a lot of changes to our camper, so we want to first make sure we are completely free of any leaks and all mold/mildew/mustiness. This is vital for us because I am very sensitive to mold and we have a tiny baby. Is it necessary to remove all rat fur just to check for leaks and mold, or is there a better way? Also, is it possible to remove the rat fur and then glue it back after cleaning behind it? We would keep track of where each piece would go, I just am not sure if the adhesive attaching it now would be too hard to get the fur off walls without destroying the rat fur in the process. And is it necessary to remove rat fur and/or insulation to alter wiring or plumbing lines?
We had hoped not to need to remove the rat fur but I am now thinking this is unavoidable due to the need to get rid of whatever is causing the musty smell.
Thanks for any and all advice as usual! Happy Friday!
SpaceBtwnWords is offline   Reply With Quote
Old 09-21-2018, 01:35 PM   #2
Leaks either come from the plumbing system or they come from the outside in. concentrate on those 2 aspects in the search of the repair. Tearing out the rat fur and replacing it isn't fun or productive. It may help you to find leaks but with allot of work, expense, and time. The most I would do is hire a furniture cleaner to clean and vacuum dry the rat fur or get a Bissel spot cleaner.
Find the leaks and repair them. If you are in a heavy humidity zone then you may also think about a dehumidifier.
Old 09-22-2018, 09:41 AM   #3
suggestion: Buy a wood moisture meter - it has 2 sharp prongs on one end - you will be able to push it into the rat fir and track the moisture to where it enters the camper.
https://www.harborfreight.com/digita...ter-67143.html
Old 09-22-2018, 10:13 AM   #4
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
One frequent source of leaks is the sliding window frames. The lower track gets full of dirt. the weep holes (slots) on the outside get clogged. Then rain bulbs up in the track and spills over inside. Use a piece of wire to poke into the slots, blow them out with air if you can. Or rinse with water.
Old 09-22-2018, 02:07 PM   #5
Trailer: 31' Airstream - Downsizing
Louisiana
Camping World service department does leak test. At least the one in my area does.
Gulfbreeze is offline   Reply With Quote
vin
"Rat Fur" insulation and Reflectix john madill Problem Solving | Owners Helping Owners 22 03-01-2018 10:30 AM
New curtains and use for rat fur walls BatDude Modifications, Alterations and Updates 10 08-30-2015 05:28 PM
Scamp rat fur: help andre robillard Problem Solving | Owners Helping Owners 6 04-29-2007 04:33 PM
Replacing Rat Fur peterh Care and Feeding of Molded Fiberglass Trailers 4 10-20-2006 11:50 AM
RAT FUR..CAT DOESN'T UNDERSTAND Susan Tiller General Chat 12 04-23-2006 10:12 PM
