Originally Posted by buellfire
I just installed this t stat in my Bigfoot. All digital and has multiple configurations. Found it as an amazon deal for $20.00. The Bigfoot had a manual t stat two wire heat w/fan only but this one should work for you.
Depending on how you use your camper this may be a big mistake. I travel in the winter at times and need my
furnace to work. All honeywell thermostats, have a hidden undocumented "feature". If the temp at the thermostat is below freezing they will not turn on. The idea is that it things fail and the house freezes you don't want to
furnace to come on a thaw it out. But with a camper if you are traveling in the winter you will likely be trying to start the
furnace with if being below freezing at the location of the thermostat. And that makes it a nightmare to get the furnace going.
It would be one thing if they documented this, but they don't and so you get surprised in the field with this.
