Replacement black water tank. - Fiberglass RV
Old 03-14-2020, 04:21 PM   #1
Marrero
I have an 85 16' Casita. The previous owner removed and disposed of the black water tank. I called Casita, but a replacement is not available. Has anyone come up with an aftermarket Replacement? I'm pretty handy and can do modifications as needed if there us one that can be made to fit.
TodPT is offline   Reply With Quote
Old 03-15-2020, 11:15 AM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
if you have a rough idea of measurements, there are may companies out there that make tanks and may have one close enough to fit, the inlets outlets are usually placed where you tell them in your order.
I did that with my trillium, I used Shirlon plastics in Cambridge Ontario
Joe
Old 03-15-2020, 02:36 PM   #3
Marrero
Thanks Joe!
Old 03-16-2020, 10:20 AM   #4
Do you have the Sealand/ Dometic 911 toilet? Where the toilet sits on the self contained blackwater tank, not the built in white fiberglass tank?
Eddie
Old 03-16-2020, 10:24 AM   #5
Marrero
Eddie
Eddie, I don't know. The tank isnt there, and the fiberglass on the shower floor is flat, so maybe?
Old 03-16-2020, 10:43 AM   #6
OK. The Sealand 911 toilet and tank was discontinued. It was replaced by the Sealand 711-M28 toilet which is currently used in Scamp trailers. The 711 tank will not work under your toilet without modification. (Threads can be found here on the modification.) The easiest thing to do is order a toilet and tank from Scamp or go with a composting toilet. The 711-M28 tank comes in a RV version and marine version. The RV version has a bottom discharge, which you need. You should call Dometic to get the proper version tank P/N if you go to another vendor. The toilet and tank are ordered separately from other vendors but shipping is cheaper than Scamps shipping. But Scamp can supply the proper drain pipe fittings you will need.
Good Luck
Eddie
Old 03-16-2020, 11:26 AM   #7
Marrero
Awesome! Thanks so much! I know where to start now.
Old 03-16-2020, 03:01 PM   #8
Contact Ronco Plastics
Jon31433 is offline   Reply With Quote
Old 03-16-2020, 03:02 PM   #9
17" Boler Trailer - Waste Water - Black Water Tank waroibns Plumbing | Systems and Fixtures 7 08-02-2020 08:44 AM
Water meter for back flushing black water tank Lockman Problem Solving | Owners Helping Owners 6 04-12-2019 03:25 PM
Draining black tank into grey tank..... Joe & Cherie General Chat 63 04-19-2017 06:35 PM
17' Boler Black Water Tank Dwight Burditt Problem Solving | Owners Helping Owners 6 04-18-2008 09:16 PM
Tornado Black Water Tank Flush Kit mitch Care and Feeding of Molded Fiberglass Trailers 16 07-14-2007 09:07 AM
