OK I’m looking for a little advice from people much more experienced and knowledgeable about electric trailer
brakes then moi.
I picked up this trailer in Sept of last year and brought it 1400 miles home. I could not lock up the
brakes as the brake controller suggested so I set it on 10 volts max, no boost. The
brakes seemed to work great with this setting. I did try higher boost but didn’t like it. I did not adjust the brakes at 200 miles as I later found out was recommended but I did jack up the wheels after the 1400 mile trip home and turn them. I felt a slight drag during part of the rotation and left the adjustment as it was thinking that the slight drag was from the brakes and they were in fact adjusted OK.
The first time I detected the wheel lockup was after the trailer had been parked for some weeks. I was just leaving on a short tip and when I just barely touched the brake pedal at the end of my short driveway and I heard a tire squeal. I tested the brakes a few times going down my street and they seemed fine again so I chalked it up to something sticking because it had been parked, but was free now and OK.
However the same thing later occurred after the trailer had only been parked overnight. This time it was raining so I wondered if that was the cause. Once again, except for that one lock-up, the brakes seemed to be good for the rest of the 200 miles trip.
Next trip was the big one, 1200 miles round trip and the brakes seemed to operate fine up to the last 100 miles or so but then were locking up often. I was able to tell it was only the starboard side wheel locking up and I think it was always that way although I could not tell prior to this. I also found that the hub was quite warm, really too hot to keep my finger on. I do check almost every stop and prior to this the wheels and bearing never felt hot to the touch (but of course the brake{s} were not locking up nearly as much also).
After the 1200 mile trip I adjusted the brakes by turning the star wheel until I could no longer turn the wheel then backing off six clicks. Some say to back off five, some say 10. I stopped at six because that is when I could turn the wheel with just a little effort. (Yes, maybe I should have done this sooner but it seems to be good.)
I then did a test drive of five or six miles and a few extra stopping tests in a parking lot. At first I thought that the adjustment fixed it, but then I found the starboard side would still lock up sometimes. I tried reducing maximum output on the brake controller to 4.5 volts and that seemed to help but I did still get the one wheel to lock-up. I think 4.5 is too low so I put it back to 10 volt max.
Suspecting that the wheel that was NOT locking up was maybe not braking, I jacked the port side up and applied brakes with the controller. I could hear it activate. At 1.5 volts I could still turn the wheel somewhat. At 4.5 volts I could not turn the wheel by hand. It sure seems to be that it is working OK on this side.
Please note that the lock-up always occur at slow speed. Application of the brakes at over 20-25 MPH works great, even if aggressive.
One thought is an intermittent short or bad
electrical connection. A visual inspection of the wiring reveals no obvious wiring problems but it would not be inconsistent with the other issues I have had related to quality control. The ground connections are typical
Scamp quality but is in good shape. I use a Tekonsha P3 Brake Control which has a number of diagnostic features and it does not show any faults. I did think that maybe the voltage was jumping up when the wheel locked, but its hard to drive and watch the controller so I’m not sure about that.
So I guess my next step is to pull the hubs and see what I see. Based on this information, what is your best guess to what is going on?
