Rivet Questions - Fiberglass RV
Old 07-01-2020, 12:58 PM   #1
Rivet Questions
I am replacing many of the rivets on my 1997 Scamp 13. I've researched on this forum but decided on rivets rather than stainless screws because I'm cheap
Rivet size - I need to replace my cord port, drilled out the rivets and found they are a hair over 3/16" thick and 3/8" length from the drilled-off end to the beginning of the bulge. Does this mean I need a 3/8" grip rivet? I assume the width is a bit over 3/16" because the rivet expands when set.
Second question - should I have aluminum rivets with an aluminum mandrell or steel mandrell or does that not matter?
Thanks!
I used these posts as primary research, thanks for the info -
https://www.fiberglassrv.com/forums/...ist-52225.html
https://www.fiberglassrv.com/forums/...art-78434.html esp post#5
nigeleccleston is offline   Reply With Quote
questions, questions, questions cathybr Problem Solving | Owners Helping Owners 4 06-22-2017 10:47 PM
To rivet or not to rivet? johnwgorman1 Care and Feeding of Molded Fiberglass Trailers 55 05-07-2015 03:48 PM
To rivet or not to rivet dykim18 Modifications, Alterations and Updates 0 08-28-2012 01:53 PM
rivet rivet kayleigh0302 Modifications, Alterations and Updates 8 03-29-2012 02:51 PM
Rivets, rivet caps, rivet gun BOBSMITH Care and Feeding of Molded Fiberglass Trailers 7 06-11-2008 09:24 PM
