Rock Guard support arms - Fiberglass RV
Old 05-10-2017, 09:45 PM   #1
Jan Dyke's Avatar
Trailer: boler
good evening. My boler came with a rock guard but what I am looking for are the support arms that have little buttons to lock it into different positions. We had these arms on an older trailer years ago. Any idea if they are available
thanks in advance Jan
Jan Dyke is offline   Reply With Quote
Old 05-11-2017, 03:05 AM   #2
Trailer: Boler 13 ft / Casita FD
Years ago I lost the factory rock guard supports on my 79 Boler. Mine didn't have the buttons and holes but a slide with a screw for different positions...Anyway I made my own with 1/2 and 3/4 inch CPVC plumbing pipe. The 1/2 slides inside the 3/4 and I have several holes to insert a 1/4 Brass bolt and wing nut at different positions.
I knotched the top of the 1/2 to fit the rim of rock guard and the bottom of the 3/4 to fit the latch lock on the bottom again a 1/4 bolt and wing nut on each end.
Hardest part of operation is lining up holes when adjusting.
Took me about 2 hours to do.
For God sake, do not drop a tarnished, brass wing nut on the ground at twilight...almost imposible to find
Old 05-11-2017, 04:48 AM   #3
Tom Trostel's Avatar
Vintage Trailer Supply sells these supports. They appear to be the same as those on my Bigfoot. Might work for you.
Stone Guard Support Arm
Old 05-11-2017, 10:44 PM   #4
Jan Dyke's Avatar
Trailer: boler
thanks guys, those from Vintage Trailer supply should do the trick
Jan
Need info re: original angle of torsion arms Henschen Duraflex rabbit Towing, Hitching, Axles and Running Gear 13 09-01-2012 08:21 PM
rock guard support needed Ricky 4 Problem Solving | Owners Helping Owners 5 07-27-2012 11:53 AM
OT: Call to Arms in BC Carol H General Chat 6 06-16-2011 01:58 PM
Bigfoot addtional rock guard support Tim D. Modifications, Alterations and Updates 3 04-18-2011 05:32 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
