09-20-2021, 08:10 AM
BC
Is this Roof Vent a problem in Trillium 1300
Hello all,
I am considering seeing a Trillium 1300 but it requires a fairly expensive trip there. It looks like a very lovely restored 1975. The pictures show the roof vent caulked. It looks a bit sketchy to me. Does anyone have advice of what might have been done here? There seem to be two layers of caulking... Would this be a problem? Would it be difficult or expensive to fix? I have not owned a trailer and am just getting into fixing things and building things myself... I would appreciate any advice! Thank you!
09-20-2021, 08:37 AM
Trailer: 1981 Trillium 5500
Peeling that off, cleaning and re-sealing is about a 4 hour job, maybe 8 if you are unfamiliar with that kind of work. more important would be the frame and flooringhas the seller provided pictures of those?
At the front of the trailer where the frame bends up, there is a weak spot that is commonly reinforced, make sure that has been done.
09-20-2021, 10:23 PM
BC
Thank you
Thank you Joe. I appreciate your advice! Apparently the frame has been reinforced by the previous owner, an airline mechanic. It looks well done except for the roof vent...
09-21-2021, 05:23 AM
If you search the site, you will find a few articles on what the frame reinforcement should look like, and a few examples of what it looks like cracked or broken.
Joe
09-21-2021, 06:47 AM
Dicor?
Hello,
It looks like the vent edge and screws were sealed with Dicor which
is as self leveling caulk designed for use on RV roofs covered with
an elastomeric membrane. The owner probably used butyl tape
between the plastic vent body and the roof. Having used Dicor on
the large 5th wheel trailer I live in I think the caulk would do a
proper job of sealing the vent. Check for any water marks on the
ceiling of the trailer.
The job done looks a little messy. If the trailer were mine I would
remove the old vent and do a proper job of reinstalling it. It would
better to get a new vent with an aluminum body that will
not deteriorate from sunlight.
Uncle Larry
09-21-2021, 08:26 AM
BC
Thanks very much Larry! Alix
09-23-2021, 08:33 AM
BC
Frame reinforcement
Hello again everyone,
I received a photo of the welded frame reinforcement. It looks different from what I expected to see (welded on plates). Could anyone with some experience give me an idea whether this looks well done and durable?
Much appreciated! Thanks in advance!
09-23-2021, 08:45 AM
Trailer: 2013 Escape 19
1. On the vent, it doesn't look original. the original roof vent had a raised flange around it. This looks like a sloppy job to me. Raised flange helps strengthen roof and keeps water away from the vent. Good design IMO.
What people do is replace the original 9 inch square vent, basically obsolete, with a 14 inch square vent (modern standard). Because of the size, they cut off the original flange to make a bigger hole, losing the advantages of the raised flange design.
2. On the frame. repair, that might be OK, but it is not the typical repair. I would like to see how the body to frame bolts are attached. The frame usually cracks vertically, right where the bolts go through the frame.
There are two bends in the frame that weaken it. First the frame rails bend inward, then they bend upward. Both bends collapse one side of the frame tubing. Often the failure is at the "inward" bend, as unfortunately, the body to frame bolt tends to be located there too.
This is just one person's opinion!
09-23-2021, 03:45 PM
Bill is correct. That is not an orignal vent. The big indication of this is the fact that it is a powed vent. I'm not aware of any 9" vents with a fan.
09-23-2021, 05:05 PM
I put a computer 12v fan in my 9 inch vent, not ideal. There is an 11 inch powered vent on Amazon. I thought about installing one of those. The objective is to keep the raised flange, that’s why I have the ruler in my pictures.
09-23-2021, 08:52 PM
BC
Thank you!
Hello Bill and David,
Thanks very much for your input, advice and opinions. I am new to this and find it fantastic to have this forum to get advice! I think I will leave this Trillium alone... It's quite far, quite expensive and maybe a bit "creatively" renovated... Not worth a long trip!
Thanks again!
09-24-2021, 08:22 AM
Bill, I think an acceptable alternative to the factory raised flange is a 1" pultruded fibreglass square tube frame.
https://www.grainger.ca/en/product/S...-FT/p/WWG4ATN8
$28.18 Canadian is not too much, and 5' should be enough for a 14" vent, (might have to round the corners a bit though). The additional height of the frame helps to keep the powered vent from hanging below the ceiling height.
09-24-2021, 10:41 AM
I like the fiberglass tubing! Need to get some. I’d be tempted to keep the original vent, and then center a 14/14 powered vent over the dinette.
On finding a Trillium, I tend to avoid the repainted ones. First, most paint jobs were poorly done. We’re all the windows and every penetration through the shell removed before painting and then properly reinstalled? Secondly, the original gel coat can last a lifetime, while paint means future maintenance.
I’d rather buy one in unmolested, but ignored/needs attention condition.
