Roof vent replacement repair - Fiberglass RV
Old 05-24-2024, 08:10 AM   #1
Trailer: Burro
Hi, first post looking for advice for my Ď82 burro.
I'm currently replacing the oringinal roof vent with a fan-tastic vent. Removing the old vent was a challenge, the old sealant did not give up easily and took much scraping with a chisel and prying and bending of the aluminum frame to get it off. Unfortunately some of the fiberglass was stuck to the sealant and came off with the frame, leaving a rough border around the hole as shown in the pic.
My question is: do I need to repair or reinforce the fiberglass around the border edge before installing the new vent? If so would resin be enough or do I need fiberglass? I think I could probably go ahead and install it with just butyl tape over the border and then seal it with Geocel Pro Flex but want to hear the communityís opinion.
Thanks!
Horsebrand has is offline   Reply With Quote
Old 05-25-2024, 03:28 AM   #2
Trailer: Boler 13 ft
Resin alone will do nothing to strenghten it.
Old 05-25-2024, 08:30 AM   #3
Trailer: Burro
So based on the damage in the picture I should definitely repair it and fiberglass is necessary? Any other options? Seems like a tough patch around the edges vs a hole in a surface. I can’t find any similar repairs in the forums, would appreciate pointers.
Thanks again.
Old 05-25-2024, 05:16 PM   #4
Here is what I did on my Casita when putting in a Maxifanvent ... I put butyl tape down and because I wanted to lift the vent due to it being alot higher them the old fan vent I took out, I got some 3/4 inch, what I call plastic wood, from Home Depot and made a frame the same size as hole. My boards were ripped 2 inches wide. on top of this one 3/4 inch layer I raise it another 3/4 inchs using the same method ... the 2 inch width coverd any holes or imperfections in the fiberglass. I then placed my maxifan on top of this. Don't worry about the edges of the fiberglass on your camper the bezel and trim that comes with you new fan, will cover all of this. Good luck ... even if you do not raise it butyl tape and trim should cover everything ... I can not post pictures sorry.
New roof vent for Trillium 4500 designed for thicker roof Vic Berger Problem Solving | Owners Helping Owners 1 07-07-2020 07:40 AM
Anyone know how to fix a saggy roof in a Boler??? (around roof vent) idiotsniff Problem Solving | Owners Helping Owners 31 11-17-2014 06:50 AM
Roof Vent Repair alidbond Care and Feeding of Molded Fiberglass Trailers 5 06-21-2014 02:31 PM
Protecting The Roof & Roof Vent Covers , AC, This Winter ???? John Cole Care and Feeding of Molded Fiberglass Trailers 25 01-15-2013 05:57 PM
To Roof Vent, Or Not To Roof Vent Frederick L. Simson Problem Solving | Owners Helping Owners 5 02-22-2009 05:41 PM
