I have a 1979
Trillium and am still having trouble finding the rubber gasket molding that fits on the door frame. My problem is that there is a variance from 1/4" to 1/2" thickness around the door frame. Most gasket material is only wide enough for 1/4" and I need 1/2". I found one company that has it...but have to buy 200 feet. Any other suggestions on sources or another way to seal. I have the flat rubber glued to the door....just need the frame gasket.
Thank you.
