Rustoleum topside paint - Page 2 - Fiberglass RV
Old 06-08-2017, 10:02 PM   #21
Johnny M's Avatar
Deep South
ID:	107127 We used Rustoleum Top Side Marine Paint both the red & white, we only did 1 coat as we ran out of time before a trip but it needs another coat or two to hide the bondo work
1971 Boler 1300 - "Suite 13"
1987 Play-Mor II - "The Beach House"
Old 06-08-2017, 10:05 PM   #22
Johnny M's Avatar
Deep South
We rolled it on with a very fine foam roller. Needs a little wet sanding in places but we like the way it looks and will like it better after the extra coats
Old 06-09-2017, 03:49 PM   #23
Kai in Seattle's Avatar
Hi!
Topside is just the name for marine-grade paint designed to go on fiberglass--boats and our trailers flex a bit more than metal things like cars and aluminum trailers. So you want a paint that will flex a bit as well. We would only us a marine enamel (primer and topside) paint on our fiberglass.
We used one coat of primer in most places...where Paul bonded or fiberglass filled we used two coats, sometimes, a small area painted right over the repair and then that was covered with an overall coat that went on everything.
then we used two coats of topside paint, both very thin and spread thoroughly with a small, "hot dog" foam roller (hot dog rollers have a covered end so you can get into small areas with the roller carrying paint).
Paul rolled it very carefully and diligently, to press out all the tiny paint bubbles. Some advocate a "roll and tip" method, which is where you roll first and then drag a "dry" brush over the surface to pop all the little bubbles. By the time Paul was done, there really were no bubbles, and the marine enamel "self-levelled" and whatever brush or roller strokes were apparent quickly smoothed out.
He sanded between every coat. The patch primer, the primer, the first and the 2nd coats of topside. So far he hasn't wet-sanded, and now that we have the decals on, I doubt he will.
The rub-on decals are "soft" and would be marred by sanding. But we may one day decide to try rolling some ZEP floor wax over it all--I hear six coats makes a lovely shine.
But we like the soft fiberglassy glow of the paint itself, and have had many compliments on it anyway.
The advantage of using Rustoleum is availability and cost and the relative softness of the paint (compared to "better quality marine enamels") is that when a rock chip or branch makes a mess, you can fairly easily put on some more paint and it will blend in easily. Paul has already filled some rock chips from our first six trips out.
Here's the real kicker--if you decided to use Durabak rubberized paint, those rocks would possibly bounce right off! We'd like one day to use some under the rig at least...but talk about pricey and hard to work with! And it has a shelf-life, once opened, of about a month., so their literature tells me. Maybe two--but certainly not a year. So our ability to use some leftovers for any mars would possibly mean buying more fresh rubber paint...though they do say you can put more on right over and it will blend in perfectly.
But so far it's sold only by mail in our area (Seattle) and the shipping of a quart of touch-up paint is costlier than the paint itself.
Back to Rustoleum.
Love that red and white combo--sharp!
I'm sure you can thin the Topside marine enamel and spray it if you want to...and I agree, two coats make a better finish than one.
Being an obsessive sander helps, too!
BEST
Kai
Semper ubi sub ubi.
Old 06-09-2017, 04:07 PM   #24
Oh, yes, how long between coats?
Paul says he waited until the paint was totally dry to the touch--some days it took 2 hours, sometimes it took overnight.
At 80 degrees out, it should dry fairly fast.
Happy painting!
BEST
Kai
Semper ubi sub ubi.
Old 06-10-2017, 07:01 AM   #25
Johnny M's Avatar
Deep South
I forgot to mention that I used the catalyst hardner by Majic Paint added to the Rustoleum Top Side paint. The catalyst hardner is mixed into the paint right before you apply it, after mixing let it sit 30 minutes then start application. It primarily does 2 things - makes the paint film harder and more durable and it enhances the glossy finish.
Majic brand "Tractor and Implement paint" (available at Tractor Supply Co.) is a modified alkyd oil base paint designed primarily for metal tractors but can also be used on wood and fiberglass (autos & boats). Top Side by Rustoleum is also a modified alkyd oil base paint but they don't offer a harder like Majic brand does.
I have painted with both the Majic and Rustoleum Top Side and I can't tell much difference in the two products. You can buy the Majic by the quart or gallon and Rustoleum I have only seen by the quart. 2 quarts was enough for 1 coat top and bottom on the Boler with some left over.
The rolling method was easy but it needs 2 coats. If I had to do it over again I would still use the hardner (it does limit the shelf life of the paint once added and will cause it to dry in the can) but I would spray it as I think it would produce a nicer finish over all.
Old 06-20-2017, 04:55 PM   #26
Bruce Thomas's Avatar
Trailer: U-Haul CT13
Lots of good info in this thread.
Bruce Thomas is offline   Reply With Quote
paint
Tremclad, Rustoleum, etc.: your experience? Uncle Cereal Problem Solving | Owners Helping Owners 8 04-09-2016 09:23 PM
Rustoleum Topside thinning Seldomseensmith Problem Solving | Owners Helping Owners 11 04-03-2016 12:04 AM
Which color Rust-Oleum Marine Topside paint to use for Scamp greendrew Modifications, Alterations and Updates 2 11-20-2014 07:55 PM
Rustoleum marine topside paint davb Modifications, Alterations and Updates 11 08-24-2014 11:33 PM
Rustoleum Paint for Fiberglass Peter_Crowl Care and Feeding of Molded Fiberglass Trailers 6 06-02-2011 07:45 AM
» Trailer Showcase
"Tupper"
Debby T.
MyBoler
artx
Copyright ©2000 - 2023, vBulletin Solutions Inc.
