Originally Posted by Alliscamp
I need to add a brace. Do you have pics of yours?
Sorry a bit late here.
Wood to the corners is a Chunk of I believe Oak cut down to conform to the curve of the
scamp roof in the little bump out area. I had to get 2 2x4s that were the right height to prop the roof to the right place, then cut down four 2 inch X 1/8th steel metal pieces stacking 2 of them and riveted them together. I over cut a bit and slightly bent the metal into an arch and connected them at the L brackets.
Now all this said... I feel since i have learned more about
fiberglass, it might be a lot easier to cut a 2 foot section out of the rat fur, sand it down from the inside, buy a thin sheet of Birch and properly
fiberglass the roof and reattach. BUT since I had never touched resin before that I figures this was a good alternative. =)
