Most likely if you have the front bath, grey water that may have been in the grey tank came back into the shower pan. The reason there is a pump for the shower water drain is that the drain is lower than the grey tank and the shower water needs to be pushed "uphill". Even if the grey tank was empty, some shower water remains in the hose going back to the grey tank.
Normally just ensuring that the drain is closed when traveling prevents any shower water from returning to the shower pan.
Another possibility if you have the front window on your shower (now discontinued) is that the seals around the window have shrunk with age, and if exposed to rain, will allow water penetration.
You might also get some drips out of the shower hose (hopefully the pump was off though) and we used to allow the shower wand to hang down to allow water to completely drain out after showers before hanging it back up.
Sharpsburg, GA
radar1-scamping.blogspot.com
