Thanks!
Here are some pics.
New hinge hardware. Both hinges are rough. I had to drill out the bottom hinge, hence the shiny new temp bolts.
I plan to move the hinges, reinforce behind the hinges with flat aluminum, and do some body work.
But when I place the door in the opening off of the hinges the door opening is out of square.
I tried pushing the roof up, bending the metal hinge side brace, and even tried putting wood bracing in along the hinge side too. No luck.
The hand glass at the bottom of the hinge side underneath looks attached, but not great. Could be an old repair not done right?
The door was also completely saturated with water. I have cut off half the inside skin and cleaned out the swollen wood, but it looks like I'll need to cut the rest out too and re glass it (and seal the window).
