Scamp 13 2012 Lift - Page 2 - Fiberglass RV
Old 12-23-2020, 01:06 PM   #21
Trailer: Casita 16
Nevada
If you are near Ft. Collins, CO I found a great trailer shop that replaced my axle. See my post at: https://www.fiberglassrv.com/forums/...ent-92692.html
kukaepe is offline   Reply With Quote
Old 12-23-2020, 02:08 PM   #22
Trailer: 2017 Scamp 13D & 2016 Highlander
Iowa
Install a Lift Kit
Michael, I have a 2017 Scamp Deluxe and it sat too low from day one. I brought it home in January 2017 and somehow damaged the toilet waste drain. I discovered the problem and replaced the damaged parts in April 2017.
I only drive on normal roads and into campsites so don't ride on bad roads very often, but in 2019 I damaged the grey water tank and the toilet waste line again. I decided a Lift Kit was the best option to avoid these expensive repairs.
I had trouble finding a lift kit so made some from 2"x3" tubing. I later found out that Etrailer had a lift kit that would have worked with my LCI/Lippert axle. It is part LC270682.
Here is Etrailer’s response when I asked if it would work for a LCI/Lippert 2200lb axle?
https://www.etrailer.com/question-377475.html?fb=yes
Here is my post to this site when I installed my lift tubes. If you are handy with a wrench this is not a bad job, just be sure to safely use jack stands to support your trailer.
https://www.fiberglassrv.com/forums/f72/need-advice-for-low-riding-2017-scamp-13-deluxe-89939.html
Here are the before and after pictures.
GpaNed is offline   Reply With Quote
Old 12-23-2020, 03:23 PM   #23
Jan Dyke's Avatar
Trailer: boler
I put a new flexride with adjustable arms set at 10 degrees up on my 13 ft boler and added 4 inch spacer. It gave me lots of extra clearance
Jan Dyke is offline   Reply With Quote
Old 12-23-2020, 04:47 PM   #24
Maryland
This is exactly what I'll be needing, thanks for the links.
Bridget
BridgetMills is offline   Reply With Quote
Old 12-23-2020, 06:37 PM   #25
AC0GV's Avatar
Wisconsin
Extra step to install the lift kit
Note that the Scamps have a "tag" welded from the axle, up to the frame to reduce floor bounce. You could cut it and then lap splice a strap in with 4 bolts, or do it the hard way, I ground it off the axle then extended it by welding on a strap. Other than that it is a bolt on project. I measured from the brake plates to the front jack to get the axle square on the frame again. I now have about 9,000 miles on the modification. OH, JUST ONE MORE THING, THE OLD SCAMPS HAD A WELDED ON AXLE.
Axle winterizing... To lift or not to lift??? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 22 12-12-2015 06:47 PM
ON | May 25-27, 2012: EggFest 2012 Kingston Vivian L Rallies, Get-togethers, Molded Meets (Archive) 163 06-28-2012 09:51 AM
OR | Apr 26-29, 2012: Spring NOG 2012 – N. Oregon Gathering Donna D. Rallies, Get-togethers, Molded Meets (Archive) 88 05-05-2012 06:02 AM
TN | April 19-22, 2012: 5th Annual Eggscursion Townsend, TN **New Campground for 2012** TomP Rallies, Get-togethers, Molded Meets (Archive) 134 04-24-2012 08:48 AM
NC | May 3-6, 2012: Casita and Friends 2012 rally mjones12 Rallies, Get-togethers, Molded Meets (Archive) 2 01-31-2012 03:42 PM
