Scamp 13 shower fiberglass damage - Fiberglass RV
Old 06-21-2024, 07:23 PM   #1
I've discovered a damaged area in my 2019 Scamp 13 shower fiberglass (no idea how this happened, which is itself a concern), and I am seeking advice from others who have dealt with this area.
I've read several posts about fiberglass and gelcoat repair and am game to give it a try. When I gently press on the damage, it flexes, which makes me wonder if I need to repair fiberglass from the "outside" of the shower pan- the void between the wood door frame and the fiberglass shower. The frame of the door looks like a pain to remove, though.
For those who have done this kind of work, does it look as if I could repair this without removing the frame? If not, have you suggestions regarding the door frame removal?
Thanks very much!
Vince
Janet and Vincent
Portland Oregon
2019 Scamp 13 / 2017 Toyota Tacoma
Pdxrain is offline   Reply With Quote
Old 07-03-2024, 10:21 AM   #2
Hollywood
Gelcoat repair
If this is not leaking outside, under the shower you do not have a major issue.
Just carefully remove as little gelcoat as possible, fill with a marine filler and paint the surface.
I had to replace my entire shower pan and that required me to cut about 6 inches out of the pan to shorten it.
I just glassed it back to together on the bottom, faired the seam and rattle caned it.
Three years now and about 15000 miles with no problem.
Tcjmiami is offline   Reply With Quote
fiberglass, scamp
Fiberglass Damage to Casita Caryfb Problem Solving | Owners Helping Owners 12 10-14-2013 06:19 PM
Shower Pump Question (Empty shower pan in 5th Wheel Scamp) Gail Shook Plumbing | Systems and Fixtures 2 09-05-2013 11:59 AM
Sun/heat damage to fiberglass? pindraak Care and Feeding of Molded Fiberglass Trailers 19 08-18-2011 02:42 PM
Fiberglass damage and dry rot Andrea in Oregon Problem Solving | Owners Helping Owners 17 02-15-2007 12:50 AM
