Hi all,
I recently purchased this
Scamp (about 10 years ahead of when we planned buy something with a bathroom) because of the price. I knew about this hole. The PO had a blow out on a mountain road and couldn't stop. So the pass. side wheel well got shredded. It put a big hole behind the pass. wheel well on the vertical & horizontal side. It also pulled down at least one wire (see pic) and bent two of the copper gas tubes (one to the stove, the other to water heater I'm guessing).
I'm fairly handy and am comfortable with repairs but I don't know what is what. I have the original owners manual and wiring diagram, but of course that doesn't tell you what's behind the rat fur.
1. Anyone know what the switch is under the stove? (I know the toggle above it is the water pump)
2. Both wires to the water pump are disconnected and I don't know where the wires should be coming from (e.g. front or back of trailer).
3. Any idea what this black wire hanging out of the wheel well goes to? (I'm guessing to the water pump); it's just one braided black wire.
4. There's a larger gauge black wire set (with + - gr inside) that has part of the sheath off but is intact aside from the ground being exposed.
5. I can fix/replace the corners of the copper tubing with a little time & contortionist skills.
Otherwise Pluto is in pretty good shape!! ;-)
