I completed a similar repair on our Lil
Bigfoot. Removed the unsound wood. Using a vibratory cutter trimmed back to approximately 1 inch in front of the cabinet faces. Patched the hole using a piece of pretreated plywood then placed a new piece of good one side 3/8 plywood as a subfloor bridging the seams of the patch which provided an even surface to add flooring. Had some concerns about adding
weight with the subfloor so I “Googled” the
weight of a 3/8 sheet of plywood and calculated the area resulting in only adding 18-20 lbs.
