Scamp 19 shower stall seal - Fiberglass RV
Old 04-14-2021, 10:05 AM   #1
kdhanso's Avatar
In my 2016 Scamp 19 deluxe layout A the shower stall area is lined with some sort of plastic sheet material and the inside corner joints were sealed with white silicone caulk. With temperature changes the sheets expand and contract and in some ares the silicone joint had separated from the plastic. I tried resealing these areas over time but eventually every repair I’d done had failed. I also reamed out the screw holes where the plastic is attached to wood in one corner so it could flex but I still get some buckling. I ended up pulling the caulk and trying these vinyl weather seals with sticky back tape. See photos. It’s held mostly now for about 6 months but you can still see the buckling from the sheet material. I’m wondering has anyone had this issue and figured out a better solution?
Ken
kdhanso is offline   Reply With Quote
Old 04-14-2021, 05:23 PM   #2
Trailer: Boler 13 ft / Casita FD
there was a real problem in my Casita with the shower walls were not sealed well and it looked as if the walls were made on the outside of the floor or what is known as the
Base. I used Flex Tape where it was obvious that water coming down walls was just going down under shower stall Base.
I used White and if you take your time you can get this tape on so it will look good and it will flex with any movement of trailer and walls.
Old 04-21-2021, 08:24 AM   #3
kdhanso's Avatar
Gerry, Thanks for your note on using Flex Tape.
Ken
New door seal installed, no seal at top of door. Luxus Panzer Problem Solving | Owners Helping Owners 4 05-11-2018 05:18 AM
Shower Pump Question (Empty shower pan in 5th Wheel Scamp) Gail Shook Plumbing | Systems and Fixtures 2 09-05-2013 11:59 AM
No shower> Add a shower Ken C Modifications, Alterations and Updates 9 09-01-2013 12:25 AM
Adding factory Shower stall to Scamp evan Modifications, Alterations and Updates 6 05-30-2006 01:25 PM
new seal for escape hatch on Scamp Gary Little Problem Solving | Owners Helping Owners 1 03-02-2006 01:24 PM
