06-14-2017, 12:07 PM
Scamp Bed Uncomfortable - Any Thoughts
We love our 16' Scamp, but are beginning to hate the bed. Maybe I am just getting old, but after a night in the bed, my back is killing me. Our model has the rear table that converts to the bed. Any thoughts as to how we might make it a bit more welcome?
06-14-2017, 12:25 PM
Trailer: SCAMP
Evil cushions
Mattress topper. Preferably a Gel variety because they don't hold the heat and make you uncomfortable. This is a blurb from overstock.com on mattress toppers. 2" makes it nicer, 3" is better for pain, but 4" you can sink in and never get out. Super comfy till someone needs the bathroom.
Memory foam, also called "temper foam," was first developed by NASA in the mid-1960s to ensure passenger comfort and protection in airplane seats. Memory foam mattress toppers mold to the body, and then slowly spring back to their original shape. This makes them ideal for those with back or joint pain. However, not all memory foam mattress toppers are the same. Here's how to choose one that will best suit your needs.
Choosing Your Mattress Topper:
Choose a memory foam mattress topper size that will fit your bed. Memory foam mattress toppers are sold in twin, full, queen, king, and California king sizes. Because these sturdy toppers sit flush against your mattress, purchasing one sized too small or too large may make your bed look and feel uneven.
Select the density of your memory foam. Density refers to the weight of one cubic foot of memory foam; this is proportionate to the level of "memory" your topper will have. Higher density memory foam mattress toppers conform better to body weight, provide stronger support, respond to body temperature more efficiently, and are more durable than the less dense models. Most people find that a memory foam mattress topper with a density of 3 pounds suits their needs perfectly, although those with body and joint pain may want a density of 4 pounds or more.
Select a thickness. Memory foam mattress toppers are generally sold in thickens of 1, 2, 3, and 4 inches. Memory foam with a 2-inch thickness or less will make your existing mattress feel more comfortable. This is a good thickness if you're just looking to extend the life of your mattress. A topper with a thickness greater than 2 inches will change the texture and feel of your bed, and is good if you sleep on your side.
Select a cover for your memory foam mattress topper. Memory foam is naturally hypoallergenic, resisting dust mites and other allergens. However, a cotton cover with a high thread count will protect your mattress topper from dirt, dust, and stains.
06-14-2017, 03:05 PM
Trailer: 2017 Scamp 16 Deluxe
Midwest
Scamp 16 Bed
Our 16 Deluxe has the big bed and was not very comfortable as you have noted in your original post.
The solution for us was going to Sams Club and picking up a 4-inch memory foam mattress topper. (Ours was really 3-inches of memory foam and included a 1-inch slip on cover.)
Now as you know the scamp has rounded corners in the sleeping/dinning area and the bed size isn't really a standard size. So we knew that going into the decision making and purchased a queen size.
Next we laid out the memory foam on the floor (at our home) laying the Scamp cushions on top to create a cutting template. Once we traced the outline we used an electric knife to cut the excess foam.
We found the electric carving knife at Walmart for about $10.
Once done you put the bed in the scamp back together and add pillows or your choice. All done!
The sheets, memory foam cover, etc are a little large but tuck in just fine underneath without any issues.
Note: In my opinion this is a setup and forget kind of operation. We do not intend to take this up and down each night. Plus the memory foam is somewhat heavy and would be very hard to store. Our Scamp has a side dinette we use for meals.
Hope this gives you some ideas.
06-14-2017, 03:19 PM
I know Southern Mattress makes a custom fit mattress for Casitas (we have one), maybe they make a custom mattress for Scamps too.
06-14-2017, 03:33 PM
Simply a bed topper. We bought a cheapo sponge topper at Walmart for like $18 and it's worked fine. We find the smallness more cumbersome than the softness.
06-14-2017, 03:43 PM
Memory foam topper at Costco and other stores. Works very well.
06-14-2017, 05:30 PM
Trailer: Former 13’Scamp, now Snoozy
Richard, we use the self inflating back packer camping pads by Alps. When we had our 13' Scamp we used the very small ones designed for the weight and length of one's torso. These stored nicely under the cushions while seated at the table, and while using as a bed, the pads were still placed under the Scamp foam but in the direction of the way we slept. We now have a full time bed in our Lil Snoozy and use the full length "Basecamp" pads by Alps for our mattress. My wife uses hers inflated with the valve closed, while I use mine with the valves left open for a different firmness. I believe that Norm & Ginny also went with our suggestion and have had good results.
Best of luck with your search for the best sleeping surface.
Dave & Paula
06-14-2017, 08:26 PM
I/we replaced the stock Scamp foam in the dinette/bed and sofa bottom cushions with a 3-layer foam sandwich.
Now, much better to sleep on & sit on. Also, nothing to store when converting bed to dinette.
Description & pix in this thread:
http://www.fiberglassrv.com/forums/s...ad.php?t=79867
Good luck to you! ☺
Ray
06-14-2017, 10:24 PM
Trailer: 2011 Scamp 13'
Many forum members have talked about this subject for years. To find previous discussions go to the "Search" button (at the top of the page) and go to the bottom of the drop-down, in the "Search Site/Google" section and write the words "bed" or "bedding" and you will get many answers.
To find my favorite solution enter the words "Gilda bedding". For instance, look at entry #9 here: http://www.fiberglassrv.com/forums/f...amp-55213.html I creating a bedding system that can be stored when the dinette table is set up. In reality, we've just found it easier to keep the bed set up and eat a simple breakfast sitting on the bed or the "couch" or eating outdoors when the weather is nice.
The Gleeful Glamper
Gilda (Jill-da)
06-15-2017, 08:38 AM
Gilda, on our last outing, we took a newly-purchased "CLAM" shelter. The 12'. We moved our "kitchen" inside of it along with our chairs, small table to eat from with LOTSA room left over. The bed stays down. We're fair-weather campers and the CLAM proved to be a VERY valuable 2nd room to us!!
I do despise having to take the bed up and down.
06-15-2017, 09:23 AM
The three options have been mentioned: (1) custom one-piece mattress, (2) removable mattress topper, (3) new, softer foam (or a multi-grade foam sandwich) in the existing cushions.
Each had pros and cons. It comes down to cost and how often you want to convert the bed into a dinette.
06-15-2017, 11:41 AM
Trailer: 2014 Scamp 16, 2011 RAV4 V6
We use a 2 inch memory foam topper, cut to size using an old electric carving knife. It works great and, because we don't keep our bed made up, it rolls up and compresses nicely for storage. I bought a cinchable stuff bag at Big 5 to store it. It has three straps that can be tightened to compress the pad. The only problem has been that some of the red dye from the bag has leached into the foam pad. No big deal.
06-15-2017, 02:30 PM
Trailer: Scamp 2017 16-ft SD / FB
We had the same problem the bed really sucks.
Had a custome mattress made by Texas Mattress Maker. It was a real mattress like the one at home. about 8 plus inches thick. I sleep like a baby.
PS had the mattress cut in half thus 2 mini mattress which are easy to handle. Cost was about $600 or about $6.00 a night for the 100 night we camp in 2016-2017 season. Topper are nice, hot and cheap - a real mattress is cool, comfortable and cost effective.
Texas Mattress Maker is located in Houston TX @ 4619 Navigation Blvd. If interested talk to "Lax"
Henry
Henry
Houston TX
Scamp 2017 16ft FB/SD
06-15-2017, 02:43 PM
Hmmm... ours is "sponge" and maybe that makes a difference; but we've NEVER experienced our topper being "hot".
Henry
06-15-2017, 03:05 PM
We had a local mattress store make us a 3" foam pad, with a fabric cover, for our 16Ft SD Scamp. It helped sleeping a lot. but was a bit of a nusance whenever we had to get into the compartmants below. But, I had added an outside cargo door on the street side for our chocks, blocks and hoses.
06-15-2017, 05:52 PM
Arkansas
Assuming you want to keep the dinette as a dinette and just lower the table for a bed, I agree that the gel foam mattress toppers are your best bet. If the bed is permanent, I highly recommend a memory foam mattress. We sleep like the dead on it.
06-15-2017, 06:35 PM
Trailer: 93 Burro 17 ft
One more option, google Froli System. Individual adjustable springs snapped together and topped with foam, cushions, or whatever. Pricey, but a couple of members here use and like it.
06-15-2017, 06:38 PM
We bought a Queen 8" spa mattress and used an electric carving knife to cut it to shape.
In our case we modified for twin beds, but it could be stock for carving to the sizes fo the existing bed, perhaps?
06-16-2017, 04:02 AM
Trailer: G30 Elite Class C
Better Foam.
Stude
06-16-2017, 04:45 AM
I just use a flat sheet over the cousions, I could sleep anywhere , anytime. It just does not bother me. When we are both up , I put up the table, it,takes just a few minutes, and use it for what it was intended for. With both tables up , it gives us lots of counter space to do things. Carl
