A 1986... I'm wondering if the brass balls in the hinges are badly worn allowing the door to hang down from the top? How does the door fit against the body... at the top of the door? Does the door actually stick out at the bottom or does it hang down below the body? Believe it or not, the
Scamp door does hang below the body even new from the factory. Unfortunately that allows moisture to wick up the door when the trailer is under tow during a rainstorm. Make certain you have the proper gasket along the bottom of the door opening too. Some have had success using a pool noodle with a slit cut to fit along the bottom of the door. Remove the noodle when setup to camp!
