scamp gray water terminal - Fiberglass RV
Old 08-05-2011, 07:37 AM   #1
Trailer: Scamp 16'
Wisconsin
Exclamation scamp gray water terminal
Just bought 16' 2000 scamp and cannot figure out how to drain gray water tank. I see where the drain is (3" like blackwater drain) but it has no cap on it and a little flange thing sort of surrounding it.
Is it meant to stay open and just drain out gray water? Any help would be greatly appreciated!
lucileangle is offline   Reply With Quote
Old 08-05-2011, 08:50 AM   #2
There should be a valve on it just like the blackwater drain and a cap.
Bill K
Old 08-05-2011, 09:10 AM   #3
Carol H's Avatar
The valve on the grey water tank should be kept closed when in use to stop the water from dripping out - at most campgrounds its a no no to let your grey water drain to the ground. The cap is just an extra safety measure for those times when you forget to close the valve. If yours is missing you can pick one up at any RV shop. The photo is what the valve should look like - if its missing it can also be picked up at any RV shop.
Old 08-05-2011, 01:54 PM   #4
honda03842's Avatar
Name: Norm and Ginny
Trailer: Scamp 16
We have a Scamp 16 as well. Even more basically, the Scamp 16 requires you to connect the sewer hose to the black tank first and dump it and then to move it over to the gray tank and dump that.
Norm
Old 08-05-2011, 03:40 PM   #5
Cyndi B.'s Avatar
Iowa
Playing with the stinky slinky.
Cyndi B. is offline   Reply With Quote
Old 08-05-2011, 06:02 PM   #6
Yeah, Scamp never has figured out how to have one valve for dumping. When I purchased my Scamp, the PO had traded the gray water cap for one like below and provided me with a gray water garden hose. The garden hose screwed on to a fitting on the sewer elbow. Still a PITA to use, but better than moving the stinky slinky from one valve to the other mid-camping. YMMV
Old 08-07-2011, 12:41 PM   #7
Radar1's Avatar
Donna,
I purchased a cap like that for my gray water tank. It makes it easy to connect a small hose direct to my portable tank when we stay more than a couple of days, then I can just take the portable tank to the dump station. Normally we just use the slinky and move it from black and then to gray for weekend trips.
John
Radar1 is offline   Reply With Quote
Old 08-08-2011, 12:10 PM   #8
Carol H's Avatar
I use that cap as well - works well when dry camping and need to drain off a bit of grey water to a portable tote - only need about 2 feet of hose to drain it - no slinky needed.
scamp
Gray water outlet BruceH Plumbing | Systems and Fixtures 12 05-19-2023 12:01 PM
Gray Water Bill C Plumbing | Systems and Fixtures 7 04-26-2008 10:17 PM
Gray water w/out tank Janine Problem Solving | Owners Helping Owners 10 08-29-2007 03:06 PM
Gray water, pumps, etc Suz Problem Solving | Owners Helping Owners 3 02-24-2006 05:09 PM
Gray Water Backup Legacy Posts Plumbing | Systems and Fixtures 1 08-04-2003 06:49 AM
