Scamp shower pan caulk - Fiberglass RV
Old 05-11-2020, 01:10 PM   #1
United States
I happened to take a look in our Scamp 16 shower today and noticed that the caulk between the wall and the shower pan had split. The shower has never been used so I知 not worried about old damage but what痴 the best choice of caulk to fix this? It looks like it failed because the factory bead was too thin and the flexing panels just tore it apart.
Rich and Maggie Passmore
2017 Scamp 16
2018 Ford F150 XLT 4WD Supercab
St Paul, MN
rpassmore is offline   Reply With Quote
Old 05-11-2020, 04:28 PM   #2
I would remove the old caulk, then use an additional rivet or screw to pull the shower pan and bulkhead closer together to close up the gap. I would then caulk the seam with 3M 4200. Amazon has it for $14. Marine stores and home centers also might have it.
Old 05-11-2020, 05:08 PM   #3
IllAnnoy
Any good kitchen and bath silicone adhesive caulk will do fine. I'm certain that is what is used at the factory.
As Jack L said, a couple extra strategically placed fasteners wouldn't hurt.
Old 05-11-2020, 05:12 PM   #4
United States
Oh, I like that solution. Dumb question - is that shower wall tight against the exterior shell? Since I知 not yet set up for riveting, I think I値l go with a SS screw and associated hardware. Wondering about screw length. And should I use the 4200 to seal the screw hole or something like butyl?
2017 Scamp 16
St Paul, MN
Old 05-11-2020, 05:16 PM   #5
United States
I worry about flexing. Not sure I知 comfortable with bath silicone caulk holding that gap closed. I assume water running down the shower wall will end up on the OSB flooring.
2017 Scamp 16
St Paul, MN
Old 05-11-2020, 05:58 PM   #6
Good luck.. my layout four Scamp 16 has always had this problem but with the wall and not the shower pan. Re-caulked it once and found it separated after the first trip. Not a big worry for me since I dont use the shower. The flexing on the road is a problem. I doubt that caulk will keep it sealed but for your case maybe something like a flashing on the wall that overlaps the pan would keep the shower water contained.
Old 05-15-2020, 05:34 PM   #7
United States
I ended up using 3M 4200 on the shower pan/wall joint. The silicone caulk failed where it attached to the plastic trim on the top edge of the shower pan. There was virtually no adhesion, it just peeled off allowing the gap to open. The 4200 is supposed to have good shear strength and is supposed to work well with gelcoat. I値l report back.
2017 Scamp 16
St Paul, MN
Old 05-15-2020, 05:45 PM   #8
Originally Posted by rpassmore View Post
... I値l report back.
Please do.. after a few hundred miles. If anything will work for me, 4200 is likely it.
Old 05-16-2020, 09:35 AM   #9
IllAnnoy
There may be better stuff, I have towed my Scamp 80,000 miles so far with the original caulk in the shower stall and it is doing well.
The fit of the fixture may be your issue, so Jack L may have had your best solution. That is to make sure the stall is firmly attached before recaulking.
Mortar a bad idea for DIY shower pan in a 1974 Amerigo gig-16? iwannagohome Modifications, Alterations and Updates 10 09-09-2018 09:04 AM
No drip pan Dometic 4.2 Scamp 16' Vanderscamper Problem Solving | Owners Helping Owners 6 10-29-2015 05:46 PM
Shower Pump Question (Empty shower pan in 5th Wheel Scamp) Gail Shook Plumbing | Systems and Fixtures 2 09-05-2013 11:59 AM
Casita Shower Pan removal for floor replacement GMike A Plumbing | Systems and Fixtures 12 03-08-2013 10:45 AM
shower pan-17' Burro Nadine Y. Classified Archives 5 04-09-2008 08:23 PM
