Scamp window question - Fiberglass RV
Old 11-14-2017, 03:31 PM   #1
Trailer: scamp
On the outside, I pulled off the black piece of something holding the window in place, cleaned it & the place it came from. When I reinserted it, it appears to fit better than it did however its now apx 1/4" too short. Was I supposed to gently stretch it? Do I need to replace it? I have one more, maybe two days above freezing left so I'd like to fix it now.
JudyG is offline   Reply With Quote
Old 11-15-2017, 10:00 AM   #2
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
Often those rubber strips (extrusions) shrink in length over the years. I would simply fill that 1/4 inch gap with a small amount of LEXEL or similar (non-silicone). It is good you cleaned the window frame channel. When I happen to wash the Scamp outside, I direct a stream of water from the garden hose into the weep holes to wash out any debris. They should drain freely. Then make sure to towel up any water I may have sprayed inside.
Old 11-15-2017, 03:08 PM   #3
Timber Wolf's Avatar
North Florida
I had a small gap in the bottom of the seal on the front window of my old Scamp. I filled it with white caulk and after it dried colored it black with a magic marker. Looks and works good. Hey, I work with what I have, that's just how I roll.
Old 11-15-2017, 03:28 PM   #4
David Tilston's Avatar
Heating it may help it stretch. Try boiling it.
Old 11-16-2017, 08:19 AM   #5
Trailer: scamp
thanks, guys. I went with a fill-in & will try heating and stretching next summer.
replacement window glazing for rear window on 1975 scamp Josh Wink Problem Solving | Owners Helping Owners 6 07-15-2016 04:05 AM
Scamp back window and maxxair window vent SharonM Problem Solving | Owners Helping Owners 3 04-19-2013 11:06 PM
Window Gasket, Window Seal, Window Molding D Shubel Problem Solving | Owners Helping Owners 9 05-16-2011 04:30 PM
Old side window & door window needed sherry loving o Classified Archives 0 06-12-2008 03:15 PM
Installing new window seal or gasket on front window Sue A. Smith Problem Solving | Owners Helping Owners 3 07-30-2007 07:21 AM
