Does anyone know what type/size screw was used for the pop up boot in Hunter I trailers? I removed mine so I could have the boot replaced (and put them in a “safe place”… and now have no idea where that is). Since I’d like to replace them with new screws anyway it’s not a huge deal, I just need to know what type/size they were 😊
On my Compact Jr the pop up boot canvas retainer screws were 10/32 1 inch long with “fender” type washers and nylock nuts. The originals were regular cad plated, I would use stainless steel ones.
when using stainless steel screws or bolts and nylock nuts you should apply a dab of antisieze lube to the threads before putting on the nylock nut.
I know it might seem like it is not needed because of the nylon but they are even more prone to seizing than ordinary stainless steel nuts and bolts.
It is not about keeping the nut from backing off. It won't interfere with that. It is all about being able to remove the nut from the bolt at a later date.
Look up "thread galling" to understand more about this issue
