Sealing air gaps around the fridge vent area - Fiberglass RV
Old 03-18-2023, 08:38 PM   #1
My Scamp is a 2011 13ft, deluxe with oak. The last time I was out I noticed a lot of cold air coming into the cabinet area around my refrigerator. I happened to be parked with that side of the Scamp toward the strong north wind and it was about 25 degrees. When opening the silverware drawer over the refrigerator you could actually feel the cold air blowing in. When I got back to the shop with some time I decided to find the leak and do some sealing and insulating. Here is what I found when i pulled the refrigerator.
You can see the large gap between the cabinet floor and the side wall next to the bathroom and the oversized hole where the pipes go into wall for the shower. I'm confident this is how the north wind was finding its way into the camper.
Mark in Oklahoma is offline   Reply With Quote
Old 03-18-2023, 08:42 PM   #2
sealing it up
I used fire stop expanding foam to seal the large hole around the pipes and a small board and caulk to seal the gap along the floor. Then I added rubber gaskets along the sides of the opening to seal the sides of the opening around the refrigerator.
Old 03-18-2023, 08:56 PM   #3
Adding insulation while the fridge is out
I've been wanting to add insulation around the refrigerator so before putting it back in I added 2" foam board on each side and 1-1/2" foam on the top. You can see the rubber gasket in this first photo as well.
Now I'm waiting for another cold night to test it out. So far it looks like it will be a lot more airtight.
Mark
8F97ECEF-D9C5-425F-BB1D-31B3F83BC59A.jpg   0E417FD0-2FFD-4154-8236-6A6EF00B32FF.jpg
fridge
Weather striping for small door gaps. Bjkj Mason Modifications, Alterations and Updates 6 11-01-2021 03:27 PM
Gaps in pop-up roof- how to fix? - compact jr KCan Problem Solving | Owners Helping Owners 19 07-08-2021 07:39 PM
Sealing around vents on fiberglass roof (Bigfoot) oldsgg Care and Feeding of Molded Fiberglass Trailers 14 08-07-2020 06:24 PM
Closed cell expanding foam in window frame gaps babittyboo Care and Feeding of Molded Fiberglass Trailers 1 06-27-2020 09:34 AM
Entry Door Gaps Coach George Jessup Problem Solving | Owners Helping Owners 5 05-02-2006 07:09 AM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
