01-16-2017, 02:13 PM
None
Sealing floor before Allure
So for those of you who have installed Allure. Did you seal the floor before installing? What did you use? Floor/Porch paint? Polyurethane? Fiberglass Resin? Does it matter?
How did it work out?
Getting close to starting the lay, sanding the old glue off today.
01-16-2017, 03:31 PM
Trailer: 93 Burro 17 ft
Oklahoma
I've wondered about that myself. Seams between sections of wood floor could allow moisture up when traveling in a rainstorm.
FWIW, I do know that Eggcampers have FG resin coating on the top surface (only). It should seal things well enough, I'd think.
01-17-2017, 10:36 AM
Trailer: 2002 16 ft Scamp
After removing all the glue and carpet strands, the only prep work I did was to clean the floor thoroughly (vacuum and wipe repeatedly with damp cloths). Its been down for over a year now and we're well satisfied with both the look and the performance.
Al
01-17-2017, 10:37 AM
Quebec
Me when I installed "Allure" in my old "Jubilee" I simply removed the old glued tiles, installed "Allure", made a joint all around to close well.
Gilles
Bigfoot 25B21RB.
01-27-2017, 10:24 PM
Is this the same allure that Home Depot sells for homes? We just put it in our 3rd room at home and it is awesome. First room was done 2 years ago.
01-28-2017, 10:50 AM
Quebec
Yes, it is this one.
It gave a beautiful rendering.
We were very satisfied.
Gilles
Bigfoot 25B21RB.
01-28-2017, 10:40 PM
Trailer: Trails West
To prevent that situation of water from the outside coming up through a plywood joint between panels you should get underneath the trailer and caulk to seams from the outside to prevent water from ever getting into the seam. This is not a problem one would address from the interior. You don't want water getting to any cut edge on plywood as it will wick into those end grain fibers and travel further into the sheet good which can cause the plywood not only to rot but also to delaminate.
If you tried to fill such a seam with resin from inside the trailer and the seam was open all the way to the outside you would first have to go underneath the trailer and apply tape on the seam so that the resin was retained in the seam instead of squeezing out onto the ground.
Of course I myself would not take either approach. I would go underneath, do a very careful cleaning job and put fiberglass cloth and resin across the seam. As you pull the plastic squeege across the fiberglass that has resin in the cloth you will push some of the resin up into the joint and that is good but it does mean you should tape off the joint from the top side so you don't have a mess to clean up afterward.
01-28-2017, 11:25 PM
None
I did what I found that Scamp had done. The section of floor that I replaced was supported around the perimeter on either frame members, or cross members of steal. I applied butyl tape to all of the frame and cross members prior to putting the plywood back in place. This will prevent any water from getting up and around the edges of the plywood, so it cannot get into the seam. As a double measure to prevent problems in the future, the marine plywood that I used to patch the floor had two coats of fiberglass resin applied to top, bottom, and all edges.
I also had to do a little sanding to level all the seams out, so prior to installing the Allure, the entire floor was painted with floor and porch paint, this was to re-seal the areas that may have been compromised by the sanding.
Once the weather is nicer (snow and low 20's F here today) I will go under the trailer and replace the fiberglass that had to be removed around the edges, but I'm quite certain all is water tight as it is for now.
01-29-2017, 10:01 AM
Oklahoma
No, no, that's totally inadequate, you'll have to do it over........ just kidding! I think your marine plywood section just might survive for the next millenium's paleontologists to dig up!
