seven blade connectors - Fiberglass RV
Old 05-13-2017, 07:36 PM   #1
Trailer: 2000 16ft Scamp
Is there an alternate type of connector that has less issues? I have never been crazy about the design of seven blade connectors. Is there any other options?
John
The earth without art is just eh....
crowwing is offline   Reply With Quote
Old 05-13-2017, 08:14 PM   #2
real550A's Avatar
Trailer: 1982 Burro
Seven pin connectors are not a bad setup, but both male and female components must be maintained in good condition, like anything else.
In Minnesota, the tow vehicles, and their 7 pin sockets, used in the winter, are degraded by the ice melting chemicals rapidly. This solution corrodes and dissolves electrical parts quickly. That's the biggest failure of the components. Otherwise, they work quite well.
Mike in MN.
real550A is offline   Reply With Quote
Old 05-13-2017, 09:20 PM   #3
Nothing really wrong with anything that is maintained.
Old 05-13-2017, 09:44 PM   #4
Just changed mine on the van after many years, the plug was badly corroded the new one is now packed with dielectric grease and we don't have much in the way of issues with road salt in winter here in Vancouver,BC.
Old 05-14-2017, 05:51 AM   #5
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
As others have mentioned, taking care of the 7 pin will virtually eliminate problems. How and where the trailer plug is stored when not connected is a big thing. Keep it off the ground, and even put it in a holder, or use a cap, to keep it from the elements. A thin coating of dielectric grease will inhibit corrosion quite well too, I like to wipe a bit on both sides of the connection.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 05-14-2017, 08:09 AM   #6
IllAnnoy
There is a heavy duty connector available. Only problem is that the regular RV plug is more common so switching TVs or trailers becomes an issue.
look here...
https://www.etrailer.com/Wiring/Poll...FY5MDQodkE4KHA
Old 05-14-2017, 08:40 AM   #7
Normally the corrosion occurs on the backside where the wires attach to the plug, the plugs are not weather resistant and that's the side I pack with dielectric grease.
Old 05-14-2017, 08:47 AM   #8
No need to pack it in, just a thin coat does the same and is less messy. Even permanent connections, like the backside of the plug, can benefit from a bit of dialectic grease.
Sent from my SM-G935W8 using Fiberglass RV mobile app
2017 Escape 5.0 TA
Old 05-14-2017, 03:53 PM   #9
Trailer: Casita 17 ft SD
Seven Pin Connector
I use the die electric grease on mine. Have a tube I got from Western Snow Plow years ago. Use it on the light bulb bases as well. Works great.
ehoepner is offline   Reply With Quote
Old 05-14-2017, 04:15 PM   #10
John in Santa Cruz's Avatar
Mid Left Coast
I squirt my 7-blade with some DeOxit before each trip.
Old 05-14-2017, 09:14 PM   #11
I use water displacement formula # 40, works great.
Lee
Captleemo is offline   Reply With Quote
Waste blade valve Eddie Longest Plumbing | Systems and Fixtures 1 04-20-2017 08:59 AM
Need help with 7 blade wiring kit? Kardon Towing, Hitching, Axles and Running Gear 19 11-19-2015 02:15 PM
Seven wonders of Canada CharlynnT General Chat 14 04-29-2007 08:52 PM
New Type Wiper Blade Kent Problem Solving | Owners Helping Owners 13 01-04-2006 10:12 PM
