Sewer hose storage - Fiberglass RV
Old 06-09-2019, 12:24 AM   #1
Sewer hose storage
Hi all
Bought a new sewer hose and the couplings are too large to fit in my bumper on my 17’ Boler. They won’t even fit in a 4” pvc pipe. I want to secure something under the trailer to store my hose. Does anyone have any suggestions?
Thanks a lot
Daryl05 is offline   Reply With Quote
Old 06-09-2019, 01:57 AM   #2
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
Maybe get a different sewer hose that will fit in either the bumper or a 4" PVC pipe?
Old 06-09-2019, 02:10 AM   #3
Borrego Dave's Avatar
Originally Posted by Daryl05 View Post
Hi all
Thanks a lot
You don't say what size your bumper is Daryl but my SDs is 4" square and I have the Rhino hose. It's a tight fit for the twist on end connecters but they do go in if their at the tubes corners. FWIW, I tied a lanyard on the end so I can pull it out otherwise it was a pita to remove. Some folks have added 5" PVC fence tubes mounted to the frame for the hose. There are some posts/pics of those mods.
Old 06-09-2019, 07:39 AM   #4
Bruce H's Avatar
Trailer: Bigfoot 21 ft Front Bedroom
Go to the lumber yard and find a larger diameter pvc pipe and fittings. Drill some air holes in it so the wet stinky hose can dry out between uses.
Old 06-09-2019, 10:10 AM   #5
MK Evenson's Avatar
Trailer: ,Retro by Riverside RV
I added a 5" fence post to the front tongue, cut to size. Get the caps for the post and mounting clips. Found mine at a ranch supply. I use the stock 4" tube to store others longer items, like clean out wand, awning tools etc.
Mark
Former Casita owner.
If you have a choice, Please buy, "Made in America"
MK Evenson is offline   Reply With Quote
Old 06-09-2019, 11:06 AM   #6
Mark
That looks clean and lightweight. Great idea. I will go with that !
Old 06-09-2019, 11:09 AM   #7
Trailer: Escape 5.0 TA
Sewer hose storage
I bought a 5” square tube at Home Depot. At the time I was shopping online cause the nearest one was 50 miles away. They actually listed three different ones that were all called 5”. If you order, you can pickup in the store. Make sure you read the product description so you get the biggest. I got the biggest and it measures 4 11/16 inside. My hose and fittings fit nicely inside.
I bought stainless hinges and stainless spring loaded latches from amazon.
Steve
starbrightsteve is offline   Reply With Quote
Old 06-10-2019, 01:38 AM   #8
Trailer: G30 Elite Class C
Daryl maybe pick up a section of 5" Plastic Pipe
That is what we did and workd great. What you can also do is pick up a Half Bucket like half of a 25gallon Bucket and put in there take the ends off stick the two hoses in it and fit the other pieces into it, we have also done this as I'm sure they are making the Bumper Pipes much smaller.
Stude
stude is offline   Reply With Quote
Old 06-10-2019, 11:05 AM   #9
Raspy's Avatar
Trailer: Roamer 1
Mark
The fence post is a great idea! Did you use a hinge on the opposite side from the catch?
Old 06-10-2019, 11:59 AM   #10
Trailer: 2017 Escape 5.0 TA
Connecticut
Used the 5” pvc for the tube and smaller railing pvc for tray . Holds everything and easy to get to.😎
78CB6359-E9ED-4320-A4C0-5A2F18D55A94.jpg   FA72E144-7039-4A5B-83D0-8B37082AEC97.jpg
Cliff Hotchkiss is offline   Reply With Quote
Old 06-11-2019, 04:22 PM   #11
Trailer: Escape 21C
Our 5" PVC fence post was cut to fit and has ridden 6000 miles for us..works great.the end caps are held on by bungee cords wh are fixed thru a hole in the rear side of the ppost and out in the center of the end caps..tight enuf to hold the caps on.... and the post fits behind our propane tanks on our Casita I also store the wash out WAND inside. The whole thing is tied on with 4 18" heavy duty black zip ties..secure for a year so far. The zip ties go thru holes in the bottom side of the post and around the frame rails and back up into the post..2 on each side..works great.
My casting rod goes in the rear bumper ;-)
Fred762 is offline   Reply With Quote
Old 06-11-2019, 05:13 PM   #12
Raspy's Avatar
Trailer: Roamer 1
Cliff,
The tray is an excellent idea. Very creative. Where did you find the pin that holds the cap on?
Old 06-11-2019, 05:39 PM   #13
Connecticut
Originally Posted by Raspy View Post
Cliff,
🤔 Aluminum rod at HD. SS hardware also at HD. Used 4 , 1/4-28 cap screws with fender washers to attach to frame. So far towed from VT to Florida and it’s still there😎
Old 06-15-2019, 04:43 PM   #14
Love the slide out tray. What size rail is that to insert in the 5” pvc post ?
Old 06-15-2019, 07:18 PM   #15
Connecticut
Used a piece of pvc deck post slit down the middle, I think it’s 4”. Probably a little bigger, as they are designed to cover a wooden 4x4 post.
Old 06-16-2019, 11:40 AM   #16
Great. Thanks a lot !
Old 06-23-2019, 07:43 PM   #17
Trailer: Parkliner
Virginia
Thanks for the storage tip using 5" vinyl fence post. I had been searching for a better storage option for my second hose on my Parkliner. I bolted a 4' long post to the top of my battery cover between the gas bottles and front of camper. I used bungee cords to hold on the end caps and closed the bottom hooks of the cords to retain the opened caps. Using stainless steel hardware doubled the materials costs.
hp in va is offline   Reply With Quote
Old 06-23-2019, 08:41 PM   #18
John in Santa Cruz's Avatar
Mid Left Coast
note a finished wood 4x4 is about 3.5 x 3.5"..
Old 07-13-2019, 12:04 PM   #19
How did you secure tube to frame ? Thanks
Old 07-13-2019, 01:59 PM   #20
Trailer: 13 ft Scamp
Any decent hardware store ( not big box store)
Will have u shaped bolts
Easy peezie
Sewer hose storage in bumper Gattopuin64 Modifications, Alterations and Updates 29 07-19-2018 08:58 PM
Sewer Hose Storage Modification allenfoster Modifications, Alterations and Updates 3 06-28-2018 06:20 AM
End Cap for sewer hose storage tube Steve Hammel Plumbing | Systems and Fixtures 5 06-24-2013 06:53 PM
Hose Buddy --For sewer hose Kevin K General Chat 5 12-09-2012 07:37 PM
