Single propane tank bracket suggestions? - Fiberglass RV
Old 10-29-2017, 07:32 AM   #1
Patricia D.'s Avatar
Trailer: 1975 Ventura
I am interested in seeing how others have attached a single 20 lb tank to the trailer tongue. I have a toolbox next to the trailer and want to put a single tank between it and the jack. I have seen the single brackets with a metal loop but they are meant to be screwed into the body of the trailer. Would it be secure enough just screwing it to the tongue? with the addition of straps?
Patricia D. is offline   Reply With Quote
Old 10-29-2017, 07:38 AM   #2
hooking up a s/tank
coleman sells a set of j-hooks I see them on ebay. it has the nuts and washers with it. you will have to go down to your tounge and drill some holes for it to hold the tank securely. the j-hook part mounts to your tank wtth tension.
good luck
bob
Old 10-29-2017, 09:30 AM   #3
bullfrogeh's Avatar
On each of the TTs we've owned, the propane tanks were secured to the trailer frame, and not to the trailer body. Only the flexible delivery line linked the tank to the trailer body.
bullfrogeh is offline   Reply With Quote
Old 10-29-2017, 11:09 AM   #4
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Wife says I always need a picture to understand stuff,,, well here is an example of that,,,,. I don't see any mention of welding,,, a tool box and a propane tank sound like a lot of weight to be putting on the tongue with no brackets welded to it.
I have a spare tire and propane tank mounted behind the jack on my Boler. Post 139 in the link below show what I did.
Good luck !
Fred
http://www.fiberglassrv.com/forums/f...-55601-10.html
FRED SMAILES is offline   Reply With Quote
Old 10-29-2017, 12:00 PM   #5
Despite having snow yesterday, work on the trailer continues today. I will take pics of the tongue and post them later today.
Old 10-29-2017, 02:51 PM   #6
This is what the tongue looks like. There is a sort of flat plate between the box and the jack where I want to put the propane.
Thanks for your help.
Old 10-29-2017, 04:36 PM   #7
Trailer: Trails West
This bracket should solve your problem. There are various sellers supplying it. You would attach it through the plate with bolts. The cylinder will be easy to remove from it when needed. Thee are some other styles that are more substantial at a higher cost that are used by the folks who go off road. Those typically also have the ring clamp fitted for a padlock to help prevent theft. Keywords for doing an image search for additional options "20lb LPG tank bracket"
Propane LP Gas Bottle Ring 2013002 Viking Pop Up Camper Gas Bottle Mounting Ring | Hanna Trailer Supply Oak Creek, Wisconsin
Old 04-13-2020, 10:30 AM   #8
IllAnnoy
The band type like kevin shows works great...
Old 04-16-2020, 04:55 AM   #9
Doug Arthurs's Avatar
I think you could notch the front lip on your tray to allow the base of the cylinder a secure spot to sit then put the bracket on and you would be good to go. Great looking trailer. Cheers from a fellow Ontario resident.
Doug Arthurs is offline   Reply With Quote
Old 04-16-2020, 08:01 AM   #10
I made my hold downs with some flat strips of stainless steel, light chain and two turnbuckles to tighten them down.
I bent the strips into "S" shaped hooks and the chain and cheap turnbuckles to suit.
propane
Propane tank holder: going from double to single tank Uncle Cereal Problem Solving | Owners Helping Owners 12 07-06-2016 02:46 PM
Propane Tank Bracket Randy J. Problem Solving | Owners Helping Owners 2 04-30-2016 09:04 AM
mounting a single propane tank gillian s Problem Solving | Owners Helping Owners 7 07-25-2013 12:16 PM
Tongue mounted propane tank bracket? bigd-bigm Modifications, Alterations and Updates 4 07-24-2013 05:34 AM
Single propane tank holder Kevin M Problem Solving | Owners Helping Owners 4 06-28-2009 01:17 PM
