02-12-2017, 07:11 PM
Trailer: Burro
Smelly sink
Hello
I've be fixing up a 1983 Burro and can't remedy a stinky sink. I've cleaned the sink trap, replaced the drain hose and soaked the sink and drain hose with bleach-water. And still the aluminum sink still has a bad odor. Any ideas?
Thanks, Jim
02-12-2017, 07:45 PM
Trailer: Escape 21 - Felicity
About the only thing left is to pull the sink and see if the stink is crud under the mounting flange...........
02-12-2017, 10:52 PM
Odor could be coming up from the gray water tank too. If the Burro is like a Scamp, it doesn't really have a usual J or P trap that holds water, which would hold the smell back.
02-13-2017, 05:10 AM
Trailer: Boler 13 ft / Casita FD
For sure Donna the trap is the most important thing to have but making sure the trap is full of water is just important.
Jim make sure the trap is holding enough water to block any fumes (sewer gas) as is know in the plumbing trade,. And is not leaking so that the water gets down below the lowest point of top "U" and the highest point of the bottom "U".
Try some baking powder down the drain and then pour about 1/2 of vinegar and leave it for a bit.
It will bubble and scrub the sides of pipes and wont hurt the system.
I wait 1/2 hour then rinse with hot water.
I once did the plumbing in a Bar/Resturaunt and the water in the floor drains, in the bar, would evaporate.
We put a pint of cooking oil down each drain to solve this problem.
02-13-2017, 07:38 AM
Trailer: 2015 Escape 5.0TA
I use a product called Elemonate (available from Amazon) that may address this issue if coming from the tank. I have had very good results with it. Simply dissolve a tablet in water and pour it down the sink. I might even think using two tablets and filling the gray water tank, then letting it "soak" for a while would work.
02-13-2017, 07:57 AM
Are you using your sink strainer? It will drop into the drain and seal the drain when the sink not in use. Some mfg. use shower drains in their sinks, the plug screws in and seals the drain. Usually made of white plastic.
Some of the older RV white plastic traps had a drain screw in the bottom which tended to slowly leak and let the tank gas come up through the sink drain.
Eddie
02-13-2017, 09:08 AM
Trailer: 1998 Casita 17 SD
If its from the grey tank, switch out the p-trap with a hepvo valve instead. Casita is now using them. No water needed. Its a one-way bladder valve. I put one on our shower in the casita to get rid of the p trap and shutoff on the floor drain. Larry at Little House Customs has them in stock.
02-13-2017, 09:13 AM
Two questions, since I don't know much about grey water tanks, but I would like to understand better...
First, does your Burro have an onboard grey tank or does it drain to an external fitting?
Second, does an onboard grey tank have a vent, and if so, could it be the cause of the smell- plugged or something?
02-13-2017, 06:44 PM
Jon has a good point.
Does it have an outside vent or is it one of those pop-it vents under the sink?
I've had one of these vents get stuck in the open position on my bigger camper letting the odors and gases come in through the vent under the sink.
02-14-2017, 11:02 AM
Trailer: Burro
Burro sink
Thanks Everyone
The Burro has no grey water tank. The sink empties into a small plastic trap (which I have taken apart and cleaned) and then a short plastic (newly replaced) hose empties to the outside. This is why I can't figure out where the odor comes from. It's as if the aluminum sink itself stinks (which is hard to figure out how that could be). It is hard to get under the sink to see the underneath, but from what I can see and smell it all appears fine underneath. I'll try the baking soda vinegar trick. I may have to remove the sink as one of you suggested to see if it is coming from the seal (which it doesn't appear to be) - but oh how I hate working under sinks, especially the Burro, because you have to twist yourself into an inverted pretzel and suffer muscle cramps in muscles you haven't used since the last time you wiggled under a sink.
Thanks again everyone. I'll let you know if I locate the problem.
Jim
02-14-2017, 02:01 PM
Sorry, You Smell the sink Stinks.
"Winston Churchill" his answer when a lady said he smells. I used poetic license by saying sink.
02-16-2017, 06:49 AM
Casita uses a Stainless Steel sink, is yours aluminum for sure? If so some cleaners are harmful to aluminum, see here.
http://www.household-management-101....-aluminum.html
Our home's kitchen sink and surrounding counter top is one piece Stainless Steel it is good quality from the early 1950's.
When it is cleaned using a green Scotch pad the steel emits a metallic like smell.
Could this possibly be what your smelling?
Joe
02-16-2017, 10:50 AM
Trailer: 2017 Escape 19
New Hampshire
Just a thought. The trap in the drain is there to keep gases from the sewage system/tank/piping etc from escaping up through the sink by "trapping" water in the bottom of it which the gas and smells cant penetrate. Maybe leaving some water in the trap, assuming there is one there, will prevent the smells from escaping.
02-16-2017, 12:17 PM
I'm starting to wonder if it's the wood counter top. Rotten wood smell, if the sink wasn't caulked to the counter top, water could seep under it.
02-17-2017, 05:45 PM
Trailer: Scamp 13
plug the drain. then fill the sink with water. With the sink full of water you have little to no sink surface area so no smell. If the smell is still there then its coming from some place else. If the sinks smell goes away scrub it with barkeepers friend that should take any surface smell away.
https://www.walmart.com/ip/Bar-Keepe...rU-fWsr_LfLHdA
Remedy for smelly tow vehicle
Patricia D. |
17 |
09-08-2016 11:04 AM |
Smelly water problem
yyyyyguy |
Plumbing | Systems and Fixtures |
12 |
10-20-2013 07:45 PM |
Sink Grate
Steve L. |
18 |
11-18-2005 08:53 AM |
Different Sink Cover
Legacy Posts |
14 |
06-28-2003 07:30 PM |
Sink Questions
Legacy Posts |
41 |
05-26-2003 09:09 AM |
