Smoking and heating Fuse panel replacement on 2013 scamp. - Fiberglass RV
Old 07-18-2017, 11:16 AM   #1
Have already replaced my converter thinking that was the problem we're having with this smoking and heating issue. In addition to heating and smoking while we were at a campsite, the 12 V circuit breaker cut off on us on two separate occasions. However, The now knew converter doesn't seem to be the problem since the area above the fuse panel is still getting hot. Have ordered another fuse panel to replace the four-year-old fuse panel. The trailer is only four years old and this seems to be a very serious electrical problem that I have no clue as to what is going on. The scamp people in Minnesota have suggested replacing both the converter and now the fuse panel to solve this problem. I have ordered a fuse panel and hope to put it in in the next few days. I've also replaced the original battery with a brand-new one. If anyone has a suggestion as to what is going on I certainly would appreciate some thoughts on this matter.
robertmarchiony is offline   Reply With Quote
Old 07-18-2017, 12:46 PM   #2
member
Isle of Wight
sounds silly but are all the wires tight in their terminal screws?
WizWid is offline   Reply With Quote
Old 07-18-2017, 12:50 PM   #3
This smoking and heating problem has a cause and replacing parts isnt going to solve the problem if there is nothing wrong with the parts.
In order to have smoking and heating you have to have something drawing the power.
When is this problem occurring, what is heating up and what is smoking. What is being powered when these problems exist.
What has been added to the electrical system since it left the Scamp Factory.
Are the proper clearances, venting and installation procedures for the converter and fuse panel being followed. I suggest getting the installation manual for the converter/fuse panel if you don't have one.
Is your battery good and your not asking the converter to charge a faulty battery. Disconnect the battery and let it sit overnight and check the battery voltage or take it to the auto parts for a charge and load testing.
Who's the manufacture and what model is your converter/load center?
Old 07-18-2017, 02:20 PM   #4
Not silly at all. That was my first thought and would be the first thing I would check. If that is the cause, then replacing all the parts might fix the problem because you would be redoing all the connections. But then again, if that it the cause it might take little more then restriping a wire and re-tightening a screw. If there is smoke, I would expect to see burnt insulation, discolored wires, or something similar wherever the problem is.
Old 07-18-2017, 02:57 PM   #5
Smoke usually means something is getting too hot. Fire is next.
Further suggest that you take the trailer to somebody that understands what causes things to get hot.
Old 07-22-2017, 03:36 PM   #6
Want to thank all for your trouble shooting help on my scamp.
Checked all wiring and it was ok. Plugged trailer in on my driveway for 15 minutes to see what was getting hot. Wiring checked out fine. Heat seemed to be coming from a circuit breaker. Removed fuse box and circuit breaker ( Main&12 volt circuit, 30amp and 15 amp), pulled breaker to find it was shorting out. Fuse panel had slight heat melt, but seemed well enough to just replace the breaker. Installed a new breaker and all seems to be well. Taking it out to a local park next week for one final test. Again thanks all!
Old 07-23-2017, 09:46 AM   #7
Trailer: 2017 Scamp 16 Deluxe
Midwest
Breaker Question
Kinda scary having things heat up like that.....
I'm no electrician but wondering how a breaker develops a short or goes bad as I have never seen such a thing. It sounds like things melted a bit. Was it the breaker itself that melted and gave the problem away? Was there wiring nearby that got pinched etc. that could have caused the short.
Just curious if there is something to be watching out for in our Scamp......
Your original post indicated that the factory didn't seem to specifically identify the potential problem other than replacing the major portions of the electrical system. You might want to alert them to the fix as well.
- Jeff
Jeff T is offline   Reply With Quote
Old 08-04-2017, 10:50 PM   #8
Hey Jeff. Just the breaker had shorted. All wiring checked out fine.
120 AC/fuse panel heating up, smoking, lights go out robertmarchiony Electrical | Charging, Systems, Solar and Generators 10 06-03-2017 10:12 AM
Fuse Panel and Converter addition.. 79 Scamp 16 Dave Frazer Problem Solving | Owners Helping Owners 15 01-19-2015 06:23 PM
Fuse panel and 12 VDC wiring Eddie Longest Problem Solving | Owners Helping Owners 9 09-08-2012 05:53 PM
Scamp 16 - installing new fuse panel / 12v convertor John Carter Problem Solving | Owners Helping Owners 2 03-19-2012 11:49 AM
Need help with 12v fuse panel and wiring update Michael Collins Modifications, Alterations and Updates 15 03-27-2011 10:50 AM
