Using a portable suitcase 100 watt panel I install a 12 volt SAE plug on the ends of the panel leads. Then for any attachment such as battery clips or 12 volt male plug I attach a matching SAE plug.
The battery has a short lead with one so I can just plug in the battery with the wire coming out from under the battery box cover (tongue mount).
https://www.amazon.com/Sea-Dog-Polar...?tag=hyprod-20
I didn't purchase this specific listing. I believe I bought a bag of 4 so I had the matching plug to solder onto the original connection options as well as one for the house battery.
Going down the road I have a charging line for the 7 pin plug to keep the house battery charged by the alternator of the tow vehicle.
My battery use has not been sufficient to warrant needing more panel capacity. Perhaps when I retire and use camper more I will find myself drawing down against poor solar conditions for long enough that I need to consider adding more solar to the roof. Current panel was purchased as much for it being a size I could velcro to a wall in a storage location as it was for total wattage.
I was able to run the
furnace overnight at 50* thermostat and recharge the next day to fully charged on a cloudy northern Michigan day. I was around to move panel to aim at sun periodically during the day for maximum charge.
What I didn't do was check to see at what point during the day did the battery reach full charge. I checked at end of day to make sure I could run the
furnace again the next night. Set at 55* because my goal is to see it working at around 63* which will be very comfortable for sleeping and ok for waking up. My other goal was to not have it run out of power in the middle of that night. :-)
It really does depend on how many amps you draw from the battery in normal use. More you use the more you can justify the additional panels or need for a supplemental portable panel. Use tells you how many rainy days you can manage, how many cloudy but some sun days or if "chasing" sun alignment is even needed on sunny days.
Totally agree with those who put a lock on to discourage opportunistic theft but not worrying about either the professionals or the more determined thieves. Not worth it. On the other hand I'm not leaving my camp set up in the middle of the National forest while I take off for a day of sight seeing. For that sort of gone all day stuff I prefer to have the camper around people and rangers and such. Paid sites in parks or commercial campgrounds for that sort of use.
All depends in the end on how much power you use and how essential that power is to your enjoyment as to if you need 1 or 2 or 4 panels. With nothing but 2 LED bulbs and a laptop I was fine with a 40 watt suitcase panel. With a blower
furnace and modern
fridge that requires 12 volt to run even on
propane the 100 watt seems sufficient until it proves itself not enough.
Plus 1 on the 3M VHB tape to mount hole free on roof. Very High Bond double sided tape indeed. I had an
awning track installed with that stuff that never budged an inch. High winds and all, never an issue.
I will be interested to see if I can use my small electric coffee pot and a toaster to make a couple bagels and coffee for breakfast without drawing battery down too much. Or maybe just decide the heck with it I have a percolator and coleman toast stand to make this same breakfast on a stove so why add more panels to make breakfast?
