Solar trickle chargers - Fiberglass RV
Old 01-27-2022, 12:29 PM   #1
John McDonald's Avatar
Trailer: 2008 Taylor Coach 17 ft
I may be storing our car for 10 months without access to electricity. I want to know of any experience you have with small (5 or 10 watt) car dash solar panels and controllers. Success? Failure? Brand and size?
The car will likely be stored in Deming, NM from March through December under an extra tall carport, so with plenty of daylight if not direct sun except for an hour or so each day.
Cheers John
John McDonald is offline   Reply With Quote
Old 01-27-2022, 05:21 PM   #2
Battery Tender
I use a 10 watt solar charger/maintainer from Battery Tender. Works well. No issues. Switches to trickle charge when battery is full to maintain. Uses “smart” battery program protect the battery. I found the 5 watt to be too low power. I got mine a few years ago and that model is no longer made. But Battery Tender still makes newer models. Amazon carries these and other brands.
John DL is offline   Reply With Quote
Old 01-28-2022, 07:26 AM   #3
Trailer: 2016 -13' Scamp
Massachusetts
What size solar panel would you pair with the charger for a 12v battery?
herons is offline   Reply With Quote
Old 01-28-2022, 08:15 AM   #4
Thanks.
I’m using a 5 watt panel here in Duluth MN and it seems to put out a grand amount of .08 amp!! Yes that’s .08 not .8!
I’ve used the plug-in battery tender for many years and it worked great. So I’ll check out the solar combo.
Thanks again.
John
Old 01-28-2022, 08:52 AM   #5
If you are asking about a simple battery maintainer I use a 10 watt model. This will maintain a charged battery. It will not charge a low or partially discharged battery. If you are asking about charging a battery for boondocking I use a 100 watt panel
Old 01-28-2022, 09:01 AM   #6
Your first response was all I needed.
Old 01-28-2022, 10:47 AM   #7
Your cigarette lighter may be disconnected from the battery. I believe you can get a small solar panel that connects through the diagnostic port, which is live all the time.
Marv is offline   Reply With Quote
Old 01-28-2022, 12:34 PM   #8
Yes, I have a device that plugs into the OBD2 port that I attach the solar panel to. Some vehicles USB and cigarette lighter ports are only available when the ignition is on.
Old 01-28-2022, 01:52 PM   #9
Trailer: Trail Cruiser
I use a diesel tug to tow my trailer but little else. It may sit for months without use. It has two 1100 amp batteries. I use a 10 watt solar panel placed on the truck's dash and connected to the cigarette lighter to keep the batteries charged and it works well.
I've also used this panel to recharge an RV battery but it took about a week to fully charge it. The charge controller regulates the power to the batteries, preventing overcharge.
Some vehicles draw a small amount of power from the battery continuously. The solar panel should put out more power than the vehicle consumes, otherwise disconnect the battery from the vehicle (remove at least one battery cable) and connect the panel directly to the battery, not through the cigarette lighter.
You can also remove the battery from the vehicle and charge it at home to keep it topped up.
Old 01-28-2022, 03:07 PM   #10
Is your controller separate from the panel?
( I have two 130 watt solar panels for the trailer and they of course require a separate controller.) But the 5 and 10 watt panels advertised on line as “battery tenders” or “maintainers” or some other verbiage like that don’t give any specs that guarantee they really have a controller as part of the panel. I have my doubts that they are legit.
I understand the panel or controller also need a dios to keep the current from reversing at night and draining the battery towards the solar panel.
Old 01-28-2022, 06:00 PM   #11
I got this as a birthday gift from my kids a few years ago. It came with a separate charge controller with lights to show "charging" and "charged". The charge controller has a diode to prevent reverse current flow. I think any charge controller used to charge a 12 volt battery will work.
Old 02-03-2022, 08:52 AM   #12
Trailer: Scamp 16ft
Alabama
When you get one make sure to get a quality brand solar charger that monitor's the battery's condition. Last year I had one on my 4 wheeler battery, it boiled the battery dry over charging it. The "Battery Tender" brand I didn't have a problem with on one of my Jeeps battery. It was my fault on killing the battery I should have been checking it better.
Darrell in Al is offline   Reply With Quote
Old 02-03-2022, 09:16 AM   #13
Thanks all!
I do need a separate controller for my small solar panel (just like I do for my two 130 watt panels).
The companies that advertise their “dashboard” 5 and 10 watt panels as “battery maintainers” are being deceptive - surprise surprise!
I’m going to checkout Home Depot as mentioned by someone here, but now I don’t see that response above.
Cheers John
Old 02-03-2022, 11:21 AM   #14
Larry C Hanson's Avatar
Trailer: 78 Trillium 13 ft / 1998 Durango
Same Controller?
Hello John,
For camping in my Trillium I use a 150W panel and a
BlueSky Solar Boost 2000i When I store the trailer I use
the same controller with a little 'old' 10W panel. The
little panel does a fine job of maintaining the battery.
Uncle Larry
Old 02-03-2022, 11:41 AM   #15
How many and what types of batteries does it maintain? And how much sun does the panel get in the winter? In other words, where is it located? In what state?
Thanks. John
Old 02-03-2022, 12:04 PM   #16
OK John,
Battery maintained is a Trojan deep cycle 130AH (SCS225).
Panel is on the tongue of the trailer facing due south.
It gets plenty of AZ sun ... Latitude is 34N. Elevation about 5200'
Uncle Larry
Old 02-03-2022, 01:05 PM   #17
Is the battery disconnected from the trailer so no phantom loads (propane detector, circuit boards of furnace, frig. ….) are taking amps out of the battery?
Old 02-03-2022, 05:54 PM   #18
Yes John.
In the power center/charger I installed there is a fuse on the
battery circuit. I pull that fuse so no phantom loads. The solar
charge system goes directly to the battery so it is not affected
by the disconnection.
Larry
Old 02-03-2022, 08:05 PM   #19
Thanks.
solar
Question about trickle chargers sunnyone Electrical | Charging, Systems, Solar and Generators 18 10-02-2020 10:31 AM
Battery Trickle Solar Panels jimmied Electrical | Charging, Systems, Solar and Generators 7 02-23-2013 01:45 PM
Check your batteries' trickle chargers! Panoz77 Problem Solving | Owners Helping Owners 24 01-13-2011 12:35 PM
Solar Trickle Charger & Dead Battery V'sGlassSleeper Problem Solving | Owners Helping Owners 11 03-19-2010 07:29 PM
Solar Panel Trickle Charger? Steve Dunkel General Chat 17 02-21-2010 01:42 PM
» Trailer Showcase
The Bean
Barbie B
Casita
Ed F
