sticky window track solution? - Fiberglass RV
Old 05-25-2020, 05:22 PM   #1
Hi all,
Is there something safe to use on the window tracks (Casita) to make the windows slide easier?
Thank you!
biker is offline   Reply With Quote
Old 05-25-2020, 09:24 PM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
First clean the track, then spray some silicone lubricant in the track while working the window back and forth.
Good luck.
Dave & Paula
Old 05-26-2020, 10:39 AM   #3
sticky window
Gm makes a product called sillicone emulsion we used in on tracks and weather striping . cheep about 3 bucks its a paste with an applicator. In alberta we use it on car doors to pervent freeze up.
MAP 56 is offline   Reply With Quote
Old 05-26-2020, 12:16 PM   #4
sticky window
part number 1#10953014
Old 05-26-2020, 08:43 PM   #5
Originally Posted by biker View Post
Hi all,
Thank you!
Use a dry lube like Blaster or Teff Lube available at many stores like Home Depot. Our Renewal by Anderson window people told us to never use a silicone that stays wet because it will attract dirt and make things worse. We used Blaster on our windows and sliding door and they work way better. I've used it on our Casita windows and it helps a lot.
Old 05-26-2020, 09:08 PM   #6
Trailer: Trails West
I used Bostik Dri-Cote aerosol spray in my window tracks. It is not silicone based. I have it on hand all the time anyway. That is what I use on the top of the tablesaw, the bed of my wood planer and the saw blades to make wood parts slide easily on the surfaces. But when doing wood working you can't have silicone as it would interfere with putting paint, stain, glue or varnish on the wood pieces.
The Bostic Dri-Cote It is long lasting and not noticeable. It does not hurt the rubber, metal, glass or plastic. I put it on last summer and the windows still slide smoothly. But I will renew it soon when I do a spring cleaning of the exterior.
Window track insert strip on Compact Jr Talia Problem Solving | Owners Helping Owners 1 10-05-2016 04:06 PM
Installing Awning Track Craig Broughton Problem Solving | Owners Helping Owners 17 08-15-2011 02:45 PM
Awning Track Installation on Boler kevin61 Problem Solving | Owners Helping Owners 2 08-04-2008 02:49 PM
Rebuild Back on Track Rob S. Modifications, Alterations and Updates 15 07-09-2008 12:35 PM
Aussie Road & Track TTs General Chat 0 01-01-1970 12:00 AM
