Suburban nt 16 seq propane furnace removal and reinstall - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 02-09-2021, 07:10 PM   #1
Trailer: boler 1978
I just installed the thing ran it for a few days camping now I gotta pull it out to get into the cabinet area for other stuff then put it back. It is working fine.
My question is: Is the exhaust/intake cap that slides on from the outside all reusable? There is a small gasket inside the exhaust vent pipe. I'm not sure its reusable but I figured I'd make sure.
Thanks,
kip22 is offline   Reply With Quote
Old 02-09-2021, 07:44 PM   #2
mszabo's Avatar
Trailer: U-Haul VT16
It is, removing may be challenging. The two halves tend to rust together.
Take your time and work it side to side. This will also give you a chance to inspect the intake and exhaust for holes.
Take the time and clean your burner and LP supply piping and thermocouple.
Old 02-09-2021, 08:43 PM   #3
Dudley's Avatar
Trailer: 1998 Casita 17 SD
If you have the room to pull it out the front, you can leave the exterior parts mounted. I am not sure what is supplied for a gasket to the trailer body but you could probably use butyl tape as a replacement. If you leave the exhaust on, you just have to line the furnace back up with the pipes and slide it in. I have done it a couple of times on my Casita.
Old 02-10-2021, 07:15 AM   #4
Trailer: boler 1978
Cool thanks for the info. The furnace was brand new 3 weeks ago and only used for a two day camp trip so far so I'm thinking rust shouldn't be an issue yet.
Old 02-10-2021, 07:18 AM   #5
Trailer: boler 1978
I didn't mean the seal between the frame and the vent cap. There is a gasket inside the exhaust pipe on the vent cap that slides onto the furnace side. It does not look like it can be removed but I had to confirm it is reusable before I pulled it apart. Otherwise I'd buy a new one before starting. Unfortunately I'll have to pop the vent cap too. Its really tight and I had to connect the gas line on the right and swing it into place so no straight out for me... Its what makes our little RV's interesting.
Old 02-10-2021, 09:28 AM   #6
Dudley's Avatar
I wasn't aware of a gasket in the pipes and the parts manual doesn't list . Ok just found it , looks like they are permanently attached to the tubes. They should be fine. My furnace is 23 years old!
furnace, propane
First Trillium Window Remove, Reseal and Reinstall thrifty bill Care and Feeding of Molded Fiberglass Trailers 34 11-08-2018 07:48 AM
Suburban furnace NT 16 SEQ Eddie Longest Plumbing | Systems and Fixtures 7 04-05-2016 01:51 PM
How to remove and reinstall the "bubble" windows (Trillium 1300) coalminecanary Modifications, Alterations and Updates 13 10-05-2013 10:25 AM
