Surf-Side Door Hinge Replacement
Greetings all
One of the next jobs up on our Surf-Side is to replace the hinges and remount the door. It is sagging, the the hinges are worn out and are no longer straight to the trailer.
Before I start to unbolt things, I thought I would query those who have gone before in hopes of gaining some insight.
Ideally I would like to mount the hinges slightly off from their current location. The surface that the hinges mount to seem to be quite flat for the area between, and a bit above and below the current location. Has anyone had issue with moving the hinges up/down?
Can anyone tell me if there is backing wood inside the fibreglass of the door and door frame?
Thanks in advance for your replies!
Scott
