I gave it a valiant effort with countless hours and dollars spent trying to rehab the
awning windows on my 1977
Scamp. The fact of the matter is, they’re an awful design and there’s a reason why
Scamp only used them for a year and a half. It’s more important for me to have a camper that’s water-tight than one that’s completely original (and who am I kidding, it will not be near original when I’m finished with it regardless of windows).
My
Scamp only has four
windows:
Door: 14” W x 24” H
Sides: 21” W x 25” H
Front/Back: 43” W x 19” H
I plan on replacing the front and back with plexi.
Scamp doesn’t have
windows whose dimensions will work for the side. The closest RecPro has is 24” x 24”, so I’d need to widen the width (no biggies) and build up the height of the opening (a pain). Similar situation for the window in the door.
I’d like to also add a small window in the kitchen.
Has anyone done this? Have advice? Is there another way to skin this cat?
Since I’ll be doing all of this work anyway, would it be worthwhile to build up a flange of sorts around each window hole on the exterior of the camper so that the windows can be mounted to a flat and more vertical surface (similar to Uhauls)?
