Switching to a power tongue jack on a 2021 Scamp 13: what are my options. - Fiberglass RV
Old 02-12-2023, 08:29 PM   #1
Trailer: scamp 13
We currently have the a manual side-crank tongue jack on our Scamp 13. It is the one that came with it when we bought in new in early 2021. I am thinking that all that cranking, and particularly that lengthy part with no resistance, might be bad for my shoulder and back in the long run. I have heard about people using drill motors with some kind of adapter. Also, I think Scamp and other places sell power tongue jacks as replacements. What do you recommend? What are the best options? I kind of lean a bit toward using a drill motor, but I have an open mind and would love to learn more from other people. Thanks very much!
zack sc is offline   Reply With Quote
Old 02-12-2023, 09:16 PM   #2
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
Here's the socket that fits in a drill/driver to run the hand crank jack. These are easy to find and available at Walmart or Amazon. They also work on stabilizer jacks. But using an impact drill on the jacks can strip out the gears or shear the drive pin. Best to use a simple drill and not an impact driver.
https://www.amazon.com/Camco-Levelin.../dp/B01B4LW998
Old 02-12-2023, 10:14 PM   #3
AC0GV's Avatar
Wisconsin
I went to the power jack
I lost the room to crank my jack after I added more batteries, in 2018 this one was under 100$. It was a short distance to the battery and it added another hitch light. The "foot" was welded to the old one and needed to be cut off. Also I did not want to carry a drill that I needed to keep charged.
Old 02-12-2023, 10:47 PM   #4
Trailer: scamp 13
Here is what tongue jack looks like now. It the hand crank facing forward. Would the idea be that I would cut that off and convert weld something to convert to 3/4 inch drive?
Old 02-13-2023, 07:39 AM   #5
Massachusetts
The movement needed to spin the crank handle is the same when lowering the pad to the ground as when lifting the trailer once the pad is in contact. Why might the the low or no load effort of handle spin to lower the pad be more of a personal concern while the same movement, at trailer tongue weight resistance, not as much of an issue?
If the concern is the number of crank rotations (repetitive motion injury risk) for moving the pad from travel to contact height, compared to the fewer number of rotations needed to heft the tongue off the ball, well, that's a different issue.
Might a second crank handle clamped to the existing handle shorten the crank circle diameter and reduce the shoulder movement during pad lift and lower? Such would preserve the current handle position for more leverage at the greater resistance tongue lift and lowering stages.
Jon MB, (the lesser half of Bonnie RB )
Jon MB is offline   Reply With Quote
Old 02-13-2023, 12:03 PM   #6
Trailer: '06 Scamp 16
Rochester, New York
Because of a back problem, I changed the top crank jack on our Scamp to one that looks exactly like the one Ken shows. It was a direct replacement for the mounting holes and works well.
Old 02-13-2023, 01:52 PM   #7
Massachusetts
Zack's original post had the comment that the no-resistance cranking was more of a concern for him, and that's what puzzled me.
I would suspect that having to lean into the crank handle to lift the tongue off of, or lower on to, the ball would be more of a strain than mere 'windmilling' the handle around when the tow ball was supporting the trailer tongue load and there was no load on the jack pad.
I say "suspect", because our Casita has a powered jack and I don't think I'd want to cope with going back to a crank handle jack.
Old 02-13-2023, 01:58 PM   #8
Raspy's Avatar
Trailer: Roamer 1
Yes. You can cut off the crank handle, near where it exits the gearbox, and weld a 1/2" nut onto the stub. These take a 3/4" socket, which is the size of the driver I referenced. I've done this and it works well. But on my jack, I like the manual crank for extreme reliability over an electric jack.
Old 02-13-2023, 02:04 PM   #9
Rochester, New York
The electric jack that Ken and I both have comes with a crank in case of elecrtical problems.
Old 02-14-2023, 09:38 AM   #10
Trailer: scamp 13
Which one is that? Do you like it? Was the bolt circle compatible? Was that an easy install?
Old 02-14-2023, 10:09 AM   #11
AC0GV's Avatar
Wisconsin
This may be the current version
Yes the bolt holes matched. Your current jack may have a welded foot that need to be cut off for removal.
https://www.etrailer.com/Camper-Jack...-3520-BBX.html
Old 02-14-2023, 10:51 AM   #12
Trailer: scamp 13
Thanks Kenneth. No, I don't think my jack foot is welded on. My main concern is: how far does it exend down below the tongue when fully retracted, because I drive over things where the jack foot hitting the ground can be an issue? If that is the same as with my current Scamp-standard jack, that would be okay; if it extends less, that would be great! If it extends down lower (when fully retracted) that might be a problem. Do you have an idea about that?
Would you recommend this over the drill motor option?
Old 02-14-2023, 10:58 AM   #13
Trailer: scamp 13
Thanks Kenneth. No, I don't think my jack foot is welded on. One concern is: how far does it exend down below the tongue when fully retracted?, because I drive over things where the jack foot hitting the ground can be an issue. If that is the same as with my current Scamp-standard jack, that would be okay; if it extends less, that would be great! If it extends down lower (when fully retracted) that might be a problem. Do you have an idea about that?
PS. Here are the specs I copied from the e-trailer link.
Specs:
Bracket height:
Retracted: 9"
Extended: 28-1/2"
Total lift: 25-1/8"
Screw travel: 19-1/2"
Drop leg travel: 5-5/8"
Clearance:
20-1/2" From bottom of bracket to top of jack
Outer tube diameter: 2-1/4"
Inner tube diameter: 2"
Hole spacing on drop leg: 1-7/8"
Footplate diameter: 5-1/2"
Lift capacity: 3,500 lbs
Old 02-14-2023, 11:57 AM   #14
Massachusetts
...how far does it exend down below the tongue when fully retracted?...
Specs:
Bracket height:
Retracted: 9"
Extended: 28-1/2"
I interpret that as the bottom of the jack lift, as supplied, is 9 inches from the bottom of the mounting bracket when fully retracted, and is 28 1/2 inches from that bracket mount surface when fully extended.
I'd use those numbers and measure down from the current manual crank jack mounting surface to get a comparison.
What you choose to attach (whether use as supplied, or swap out for your own alternate pad, foot, or wheel) will change the offset.
Old 02-14-2023, 02:00 PM   #15
Trailer: scamp 13
Thanks Jon. That makes sense. I am actually not sure how much the jack I have now extends below, but I don't think it is less than 9 inches.
Old 02-15-2023, 11:57 AM   #16
Trailer: 2008 Bigfoot 25FB trailer
You have a couple solutions I have that exact jack on a utility trailer I converted it be used with a socket like others have described. Only I disassembled the handle and replaced it with a 6" bolt of the same diameter( not for the un mechanically inclined but it worked for me).
a couple other suggestion is have you considered a flip foot like this link
https://www.fastwaytrailer.com/flip-jack-foot. I use this on our travel trailer and like it very much.
or a block of wood or a jack cone like this
https://www.amazon.com/Valterra-A10-.../dp/B000BGHVSM
to put under the jack reducing the # of turns?
or a drop foot on the jack similar to this
https://www.amazon.com/Libra-Standar.../dp/B017V0VF7I
Best of luck, save your shoulder where you can, I have severe arthritis and relate!
2008 Bigfoot 27.5FB Anniversary Edition
Tug 2005 Suburban 3/4 ton with 8.1 liter engine.
Martin A is offline   Reply With Quote
Old 02-15-2023, 12:45 PM   #17
Trailer: scamp 13
choices for power jack
Here are the choices I am looking at at e-trailer. I wonder how much better the $263 Stromberg Carlson (SC63VR) or the $202 Stromberg Carson (JET-03555) are than the $144 E-trailer brand choice?
What would you recommend? I kind of would like the best, smoothest most reliable thing, hopefully with a manually option that works well. Do you think you get more by spending the extra money?
Old 02-15-2023, 01:06 PM   #18
Look at the Barker brand I have had two and very happy with them, you can rotate the head to get tailgate or hatch clearance if needed. Good customer service when one arrived damaged.
https://www.amazon.com/Barker-30828-.../dp/B000UO7ZYU, there is a 3000 lb one as well. check that the post diameter matches the hole in your mounting spot. there is also a version with a 24" stroke which is what I have as the top of my frame is 26" above level surface
To me the extra cost is worth it.
Old 02-15-2023, 03:36 PM   #19
Trailer: 16' Standard
Ohio
I have the Ultimate Jack
https://www.etrailer.com/Trailer-Jac...22-RDJ-2K.html
Very little free cranking.
Kenny in Ohio is offline   Reply With Quote
Old 02-18-2023, 02:14 PM   #20
Electric tongue jack
If I had known how Awesome an electric jack would be, I would have had Scamp install it from the start. Mine's a 2021 16ft. After a year of cranking, cranking, cranking, my husband ordered an electric jack from Scamp for Christmas. He had no trouble switching it out. Plenty of clearance when it’s fully up. I’ve had both knees replaced and back surgery in 2021. I love it! I attached what Scamp uses. The company charges $229. Not sure what Scamp charges. Brand is Stromberg Carlson.
BLaughlin is offline   Reply With Quote
Power options when not hooked up to external power source Vic Berger Problem Solving | Owners Helping Owners 35 12-01-2020 06:13 AM
Options, Options Options Tezha Problem Solving | Owners Helping Owners 8 09-19-2010 11:55 AM
Trailer tongue power jack The Hobo General Chat 9 02-24-2009 02:52 AM
Power tongue jack Legacy Posts Modifications, Alterations and Updates 20 07-20-2003 02:42 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
