Tail Light or Turn Signal Light Remaining On All The Time - Fiberglass RV
Old 12-26-2024, 12:57 PM   #1
Happy Boxing Day..
Well not so happy because I stepped out side this morning and noticed that the right turn signal light or possibly the right tail light on my 1975 Trillium is "ON".. The trailer is plugged into 110 for the winter and there is a solar panel..
I have no idea what is going on so any ideas as to what is happening and/or how I can remedy this situation would be much appreciated..
Chris from Comox..
Chris from Comox is offline   Reply With Quote
Old 12-26-2024, 01:35 PM   #2
Probably a short in the trailer plug. Between the power wire and the turn signal wire.
Old 12-26-2024, 03:31 PM   #3
Mary and Bob..
I have just spent the last hour testing everything including unplugging the 110 and 12 volt, from the battery to the wiring and have come to the conclusion that, because the other tail light and the 4 clearance lights that are on the same circuit don't come on, that the tail light fixture itself is faulty and requires replacement ;-) Oh yea.. Wish me luck,, The trailer itself is going to be 50 years old next week..
Chris from Comox..
Old 12-26-2024, 08:09 PM   #4
CharlesinGA's Avatar
It could easily be the brake/turn signal you are seeing on, and that could be conductivity across the plug or a short in the wiring. I doubt it is the light fixture.
Check between ground and the right turn/brake terminal with a volt meter. Compare it to the left side terminal.
Charles
'03 Ram 2500 CTD, 5.9HO PacBrake six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 12-29-2024, 02:41 PM   #5
Charles..
Thanks for this suggestion.. I am not a knower of all things and as such I could use your guidance.. I am assuming that you are suggesting that I check the continuity between the left light and then right light.. If my assumption is correct then even without then even without utilizing a multimeter I know that there is continuity with the right light because the light is actually “on” and I can see there is no continuity with the left light, because the light is not illuminated.. ��
Am I missing something??
In the mean time I will take your recommendation because I just might learn something ��
Chris from Comox..
Old 12-29-2024, 06:04 PM   #6
What you are looking for is continuity between the black wire (battery power) and the brown wire (right turn light) as shown in the above illustration. Since they are next to each other in the plug that is most likely where your problem is.
Old 01-01-2025, 11:26 AM   #7
Trailer: scamp
Indiana
Yeah I have had so many problems with that plug on multiple trailers. Horrible design. I ended up like giving on repair --- repair -- repair --- repair of the wiring inside this plug. I found a factory pigtail that has the plug molded to the wires and then has a junction box that you hook the trailer wires to. I then even added a way to purposefully turn the lights on when I want to. Here is a post I did on that
https://www.fiberglassrv.com/forums/...ug-102616.html
computerspook is offline   Reply With Quote
light
LED Tail Turn Signal Running Lights for 13' Boler HawkBoler72 Modifications, Alterations and Updates 10 05-27-2016 09:14 PM
Brake/turn signal light problem captsteve2002 Problem Solving | Owners Helping Owners 14 05-28-2015 08:18 PM
Right turn signal and brake light problem dlux Problem Solving | Owners Helping Owners 2 06-09-2014 09:36 AM
Back to tackling that missing left turn signal... Bobbie Mayer Problem Solving | Owners Helping Owners 16 09-08-2007 11:01 AM
13' Scamp - Left turn signal and brake light Kate Carney Problem Solving | Owners Helping Owners 7 07-23-2007 08:55 AM
