Originally Posted by koy
Hello, i have this new tekonsha prodigy p2 trailer brake controller just install on my honda oddessy, but i just don't know how to set it up ? I call the manufactory tech. ,but they said that every trailer are different weight, so they don't tell me what to set it up. My 16' casita is about 2300 lb. Gross weight. Do any one know how do i set my brake controller at or use it .this is my first brake controller , i'm still learning -thank-you.
The way you are supposed to set it up is to drive about 1/4 mile or so with the manual lever at 1/2 way to warm up the
brakes. Then you can stop and pull over, switch the manual lever all the way to the left and then use the scroll wheel to set the
brakes to maximum "13". Then start driving again and brake with the manual lever by putting it all the way left. Have your window open so that you can hear if the
tires are locking up. If they are lower the brake power to 12, then to 11, then to 10. Until you no longer here the
tires locking up.
