tire and rim size for 74 pacer - Fiberglass RV
Old 03-17-2017, 08:47 PM   #1
Trailer: 74 perris pacer
Hi, I ordered run of the mill tires and rims from ebay, package deal. I put them on today and naturally the tires rub the wheel well skirt. Who knew there's something called 'back spacing'? I do now after reading up on tire and rim sizes ad nauseam. I'm returning them. Anyone had luck ordering a package deal that fit? The size I ordered is 175/80R13. Thanks for any comments
hangemhigh is offline   Reply With Quote
Old 03-17-2017, 11:04 PM   #2
Recstuff.com - Trailer Parts, Tire and Wheel Superstore I have ordered from these people several times and been very happy.
Old 03-17-2017, 11:42 PM   #3
thank you..I'll call them in the morning.
Old 03-18-2017, 07:33 AM   #4
Did the wheels you just purchased have zero offset ? Most all trailer tires have zero offset. Perhaps the axle on your trailer was changed to a wider axle?? If that is the case, standard trailer wheels will not work.
Old 03-18-2017, 07:34 PM   #5
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
Good luck on the replacement. They've got to be right!
Sue and Henry is offline   Reply With Quote
Old 03-18-2017, 08:33 PM   #6
no, zero does not work. I looked at thinner tires but not much to choose from.
Old 03-18-2017, 08:49 PM   #7
thanks, I'm on the hunt for rims..I have the spare with the same size tire and it fits, so I have the correct template.
Old 03-19-2017, 03:03 AM   #8
If zero offset wheels and 175-80-13 tires rub you might have sagging suspension or some previous owner changed the axle to a wider one.
increasing rim/tire size to gain ground clearance sjack541 Towing, Hitching, Axles and Running Gear 12 12-13-2014 05:20 PM
Beachcomber 15 Tire and Rim size little sunshine Care and Feeding of Molded Fiberglass Trailers 1 04-27-2014 12:30 PM
tire@rim size cram66 Modifications, Alterations and Updates 3 05-20-2012 02:52 PM
What size tire for a Perris Pacer? Vickie B. Towing, Hitching, Axles and Running Gear 6 07-29-2010 06:54 AM
