Top jalousie window aggrevation - Fiberglass RV
Old 12-30-2020, 10:08 AM   #1
Trailer: 1974 Trillium 1300
FL
So, my 1974 Trillium has original jalousie windows, 3 pane. I am trying to replace the gaskets in them and the top j seal, but it is impossible to remove the top glass panel. I cannot seem to find any videos of someone actually removing the single window- plenty of them removing the entire thing to reseal with butyl- but I have already done that. Likely I should have replaced the seals when the window was out, but there HAS to be a way to pop out the top windows just like the lower two.
How do people remove the top jalousie window?!
Thanks
miarosa is offline   Reply With Quote
Old 12-30-2020, 10:17 PM   #2
I just removed all the jalousie windows, but not the frames, in my '73 Trillium.
Once you have all the screws removed, it's a matter of getting a flat screwdriver in between the small bracket and the window frame, you can see by the other windows which way they have to go. You will have to be a little forceful and it helps to curse, but keep wiggling and eventually it will come loose enough to pull one end out.
Hope that helps, sorry I don't have any pictures.
Tim from BC is offline   Reply With Quote
Old 12-30-2020, 11:35 PM   #3
FL
Hm. There are the small triangle pieces that the screws go into- they appear to be plastic. i was able to tilt the window pane up and it lifts off that piece it rests on/screws into. Yet, it still won't come out. They don't appear to just lift out. We've been worried that we'd bend the aluminum.
Old 12-31-2020, 07:30 AM   #4
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
To change just one, I think you would have to remove the bottom portion of the aluminum frame (for that section) then wiggle the glass out, I don't think the pane with it's surrounding frame comes out as a single unit
Old 12-31-2020, 08:39 AM   #5
FL
They absolutely do. Each pane is able to be entirely taken apart, 4 sides, gaskets, and glass. I imagine it would be almost impossible to put new gaskets in and wiggle the glass into 3 sides of the frame.
Old 12-31-2020, 09:16 AM   #6
Trailer: 1975 Triple E Surfside
I'm rebuilding my Jalousie windows on the Surf Side which are the same windows. I'm having to take them apart and clean the paint off them and replace the seals and the actuators. I was going to make a video today .. so I'll post that later.
Retired and love new projects.. and blog about them
https://www.robeye.ca
robeye is offline   Reply With Quote
Old 12-31-2020, 10:32 AM   #7
I'm not sure what to say, that's how I got all my windows out.
Sorry I can't help.
Old 12-31-2020, 10:41 AM   #8
Sorry I can't help.
Your not wrong Tim.. The glass is wedged in with a rubber trim. and will need a bit of persuasion.
Old 12-31-2020, 11:10 AM   #9
I hope this will help.. With the window open ..
On both sides you will find this .. Removing these two #6 Robertson screws (both sides) the frame will just slide out. Then there are four more screws on each corner of the frame.
These hold the frame together and the glass in..
Old 12-31-2020, 11:56 AM   #10
FL
Attachment 138940
Attachment 138941
So I have 2 screws on each side, at the triangle like pieces. After removed, the window pane does not slide out. There is a lip on the top of it, plus the edge of the top frame of the window, which prevents it from just sliding right out or popping it up and out.
I will take pics when I try again after the rain. It's so frustrating as everyone says they slide out, but mine simply do not, and I bought all the gaskets already lol
Old 12-31-2020, 01:07 PM   #11
You are right.. The top pane will not just slide out.. The others do but not the top.. The top window frame is too close. And since the triangle piece is also the hinge pin you can't spread it far enough. since I have the windows out I have no problem.. Let me see how to do it without removing the window. Gota be a way.
Old 12-31-2020, 01:09 PM   #12
FL
Exactly! I'm able to get all of the lower windows out, just not the top ones.
Old 12-31-2020, 02:53 PM   #13
Got it ! I'm taking mine apart anyway... Looking at the window from outside .. there is a tab on the left.. but not on the right. So with a little gentle prying the right side will move down and out. and the left just comes too. So strange that those tabs are there .. give it a try worked for me..
Old 12-31-2020, 05:01 PM   #14
FL
hmm i do not think i have any tabs
Old 12-31-2020, 05:50 PM   #15
Ya I guess that's confusing. here's two pics that will explain.
This is the tab I'm referring to
As you can see it's not there on the right side of the window pane
Old 12-31-2020, 05:56 PM   #16
FL
I don't understand how that tab impacts removing the window pane from the main frame.
Removing the window from the fiberglass wall of my camper isn't an issue.
If that tab is on the exterior of your window, we have different windows. Your very first pic with the j seal is the location I'm having issue with.
Old 12-31-2020, 06:02 PM   #17
FL
This older post, https://www.fiberglassrv.com/forums/...rip-63982.html , shows the same windows I have, as well as the same unresolved issue.
These windows will be the death of me! Lol
Old 01-01-2021, 12:47 PM   #18
FL
Here is a pic of my back window. The cracked j seal along the top shows where the window won't lift out from. There are also no tabs anywhere
Old 01-01-2021, 01:52 PM   #19
Those window panes look the same as mine.. When it stops raining ... open them up and look to see if you can see these differences.
On the left side of the pane (on mine) there is a piece of the top on the back side that extends out preventing you from pulling the pane down. in the circle.
On the right side .. (on mine) not there.. Allowing me to pull down on the pane enough to clear the top frame.. then lift that side and the pane will come free. Done with the window half open.. You may have things different ?
Old 01-01-2021, 02:28 PM   #20
FL
hmm its hard to tell what is behind mine, since the window is in. There doesn't appear to be any tabs though. After the rain I'm going to take a lower one out again and see, as I'm able to take those ones out, just not the top.
Thanks
Jalousie window operator for original Boler window Dave M Problem Solving | Owners Helping Owners 2 05-29-2012 08:33 AM
jalousie window crank repair Roy Massen Problem Solving | Owners Helping Owners 10 06-02-2009 06:37 PM
jalousie window repair Eileen S. Problem Solving | Owners Helping Owners 7 04-14-2008 10:26 PM
Jalousie Window - replace with glass or plexi? Daisy Problem Solving | Owners Helping Owners 7 05-24-2006 04:04 PM
I'm looking for a small jalousie window... Legacy Posts Problem Solving | Owners Helping Owners 3 02-04-2003 08:17 AM
