Top jalousie window aggrevation - Page 2 - Fiberglass RV
Old 01-01-2021, 04:11 PM   #21
Trailer: 1975 Triple E Surfside
Let's see if this will help.
https://youtu.be/QtDdikDe0pA
Retired and love new projects.. and blog about them
https://www.robeye.ca
robeye is offline   Reply With Quote
Old 01-01-2021, 04:45 PM   #22
Trailer: 1974 Trillium 1300
FL
Oh! Thank you so much for the video! I'm sure now that our windows are different. I pulled one of the lower ones and took some various angle pics. No tab anywhere.
miarosa is offline   Reply With Quote
Old 01-01-2021, 04:47 PM   #23
FL
The sides where the screws go is also different
Old 01-01-2021, 05:09 PM   #24
Yup That's different.. What the heck is holding the pane in ?
Old 01-01-2021, 05:38 PM   #25
FL
in one of the sideways pics above, you can see like a step pattern where the gasket lies. That upper lip part sits beyond the hinge where the screws are.
Old 01-04-2021, 11:59 AM   #26
brendadave's Avatar
Trailer: 1976 Trillium 13 ft
I'm in the same boat with my Trillium, I was doing the same work this summer, I could get the bottom two panes out, but not the top one. it would keep getting stuck because the frame at the top was too close to move the window enough to remove it.
If I remember correctly, with a lot of frustration I did get one of the side top panels out, but I think that is because they are longer and had more room to work, but the back windows, no way.
Old 01-04-2021, 12:18 PM   #27
FL
I'm glad? sad? it's not just me lol. I was able to renovate my entire camper, learn electrical work, fiberglass work, ect, but taking a window out?? apparently not. lol
Old 01-06-2021, 11:45 AM   #28
Trailer: 1975 Surfside (not Triple E)
Originally Posted by robeye View Post
I'm rebuilding my Jalousie windows on the Surf Side which are the same windows. I'm having to take them apart and clean the paint off them and replace the seals and the actuators. I was going to make a video today .. so I'll post that later.
Attachment 138938
My '75 Surfside has knock-off Jalousie. Can tell as they dont have a date stamp like the Hehr's and the seals are slightly different
kipper is offline   Reply With Quote
Old 01-06-2021, 12:17 PM   #29
Trailer: Scamp 13, 1980
AZ
Can I ask where to get replacement gaskets? I have been meaning to post -- the jalousie window in the door of my 1980 Scamp 13 needs a new rubber gasket above the top window pane -- it is dried out and broken. What do you call that part and where can I buy it? Do you need a photo?
thanks,
Tracy
TracyG is offline   Reply With Quote
Old 01-06-2021, 12:24 PM   #30
Vintage Trailer Gaskets or Vintage Trailer Supply
I used VTG with great results but it seems more common to use VTS with similar great results. I chose VTG based on availability of product mostly
Old 01-07-2021, 10:49 AM   #31
AZ
Can I ask what the part is called? What would I look for? I've not been able to find anything that I think looks like the gasket I need....
Old 01-07-2021, 11:45 AM   #32
FL
j seal/top seal
this is the one i have for my 4901 windows. hope you have better luck taking the top one out, which i'm like 99% sure has to be removed to swap the top seal, because i can't just slide out my old cracked ones.
https://www.vintagetrailergaskets.co...e-windows.html
Jalousie window operator for original Boler window Dave M Problem Solving | Owners Helping Owners 2 05-29-2012 08:33 AM
jalousie window crank repair Roy Massen Problem Solving | Owners Helping Owners 10 06-02-2009 06:37 PM
jalousie window repair Eileen S. Problem Solving | Owners Helping Owners 7 04-14-2008 10:26 PM
Jalousie Window - replace with glass or plexi? Daisy Problem Solving | Owners Helping Owners 7 05-24-2006 04:04 PM
I'm looking for a small jalousie window... Legacy Posts Problem Solving | Owners Helping Owners 3 02-04-2003 08:17 AM
