Trillion electric problems - Fiberglass RV
Old 08-12-2017, 06:33 PM   #1
Trailer: Trilium
Interior lights and not working, but electric socket next to door works.
Dalknob is offline   Reply With Quote
Old 08-12-2017, 06:46 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Curt,
If your Trillium has the original electrical equipment, the outlet near the door is of course 110 vac, while the interior lights are part of the 12 vdc system. With original Trillium wiring, the 12 vdc system is simple:
(1) a press button circuit breaker and a battery/transformer rocker switch (black) on the right side of the converter box front panel
(2) a transformer inside the converter box
The converter box also has a 110 vac circuit breaker on the left side of the converter box front panel.
The rocker switch should be in the transformer or "TRANS" position.
-John
Propane & Electric vs Just Electric Wallo Care and Feeding of Molded Fiberglass Trailers 75 03-06-2014 06:24 PM
All electric, or gas and electric? Homer Teitsma Electrical | Charging, Systems, Solar and Generators 24 10-07-2007 11:10 AM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
