Trillium 1300 1973 how to remove sink faucet - Fiberglass RV
Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 10-11-2021, 07:59 PM   #1
kimnmiller's Avatar
Trailer: 1973 Trillium
Hi,
I have a 1973 Trillium 1300.
I'd like to now remove the sink faucet fixtures to make room for a wooden countertop to fit over the stove and sink basin (I'll leave the basin in as I use it for storage. I am not using the water in the trailer so don't need faucets). The faucet pump came out easily enough, but how do I remove the water faucet? I can't see an easy way. Is there an access point for it?
See picture for what still needs to be removed please.
Thanks for any help and advice!
Kim
kimnmiller is offline   Reply With Quote
Old 10-15-2021, 04:22 AM   #2
Trailer: 1976 Trillium 1300
New Brunswick
Trillium 1300 1973 how to remove aink faucet
Hi
To remove the faucet you must unhook the water line and a large hex nut from the tap under the counter top . It may require a basin wrench to loosen the nut, the space is small. Home taps are the same set up.
If you take the sink out the job would be easier to do as well. Pliers should work for temoving the nut then.
Use a mirror to see the tap and determine which method will work best.
Good luck with this , Regards ,Duane
getaway1 is offline   Reply With Quote
Old 10-25-2021, 12:25 PM   #3
kimnmiller's Avatar
removing sink faucet
Thanks Duane I appreciate the help!
trillium
ordering a sink faucet for a 13ft. Trillium lloyd cicetti General Chat 3 08-05-2018 12:55 PM
Tool to use to remove boler faucet nzwasp Problem Solving | Owners Helping Owners 6 06-29-2017 01:20 PM
Sink Faucet and Drain in 2006 Trillium & etc Nichole Adams Plumbing | Systems and Fixtures 9 09-08-2009 10:08 PM
Looking for Sink Faucet georgia g Problem Solving | Owners Helping Owners 6 06-21-2009 07:03 PM
