I thought that I posted this before.
About a week after I picked up the
furnace and
fridge from Lyle P, a member of FiberglassRV.com sent me a message about trouble they were having with the pilot
light on a Duo-Therm 65810-002 furnace. It would not
light. I suggested that they pull off the tube that feeds the pilot
light and blow through it. Also, while there was gas pressure on the furnace, and the tube was off, push the red dial and see if any gas came out. They did both, and all seemed good. They then pulled out the pilot burner and found that no gas was going through it. I offered to send one to them, but I wanted the blocked one in return. Before I even started look for a pilot burner, the blocked one arrived. This turned out to be good. Having an example of what I was looking for allowed me to compare it to the 11HU furnace that I got from Lyle P. It was the same burner, even though they were different furnace models. I took the pilot burner off that furnace and blew through it. It was not plugged. I sent it off, along with some
high temperature gasket compound. I hope it works for them.
I ran the plugged burner through an ultrasonic cleaner and it is no longer plugged.
