Depends on the condition of the plates. The majority of steel plates in my
Trillium 4500 were badly rusted, many of them just brown powder. This extreme corrosion resulted in the
fiberglass outer shell around each plate bulging outward 1/4" or more.
I ground out/cut out the
fiberglass bulges and most of the plates (at least 40 plates). Then I sanded and cleaned out the center seam with acetone and patched it with
fiberglass.
If the plates are intact, I don't believe they need to be removed. Just need make the seam water tight to prevent rusting.
